Old 02-02-2009, 09:28 AM
Bigbloke is on a distinguished road
Int 30 taper question
Hi
Hopefully this question is Ok on this forum...
I have a Bridgeport clone with an INT 30 taper on the spindle.
Is it normal for Int30 spindles to rely on the taper / drawbar for locking ? mine doesnt seem to have any drive lugs on the end of the spindle.
My previous machine (also int 30) did have driving lugs that engaged with the flange on the toolholder.
Any thoughts much appreciated.
Paul
Old 02-03-2009, 04:35 PM
JohnnyTurn is on a distinguished road
BB,
Yes, there should be atleast one drive ear/lug. 30 is small but if you put a 3/4 emill in there and you do some hogging, watch out!
There should be a provision for a lug. If there is, just make one out of mild steel. Mine is still holding in my old Shizouka from 16 years ago.
JT
Old 02-04-2009, 09:14 AM
I have now figured out what the problem is with the Int 30 taper, turns out its an R8.
Slightly embarassing but I'll get over it.
Paul
What's the taper on this? la_coterie Commercial CNC Wood Routers 4 02-20-2010 02:15 PM
Cat 40 Taper wickedcool General Metalwork Discussion 1 06-26-2008 02:01 PM
Taper 40 N.S. professor Industrial Hobbies (Support forum) 2 01-13-2007 07:14 PM
taper question! bigblock General Metalwork Discussion 2 12-23-2006 09:03 PM
R8 taper lt paul General Metal Working Machines 2 06-10-2004 10:31 AM
