Old 01-30-2009, 11:14 AM
kewl_cat is on a distinguished road
Cool Series 1 Z Axis Lube Metering Unit
I recently reworked my Series 1 Lube System with new metering units from Lube USA. Everything now works great except for the Z axis screw is still not getting way lube. The quill is getting some but not the Z ball screw. Really tiresome having to squirt some way lube on the screw everyday... Anyway does anyone know if there is a metering unit on the z ball screw itself? I am getting lube to the T on the side where one goes to the quill but not the one going to the ball screw. The plastic line goes up into the head and disappears. Just thought I would ask before I start disassemblin'....
Metering/Dosing pump pds Mechanical Calculations/Engineering Design 28 12-03-2008 02:31 PM
Need Help!- Steps Per Unit” in “Axis Calibration Problem Mr.Chips Mach Mill 6 09-02-2008 08:45 PM
Home Made 4th Axis with Harmonic Drive Unit! widgitmaster Benchtop Machines 30 06-05-2007 11:14 PM
Looking for info or manuals for old bijur lube... on BP series 1 peter.blais Bridgeport and Hardinge Mills 18 10-17-2006 04:05 PM
Sony 2-axis Servo Unit 2020b rosli Servo Motors and Drives 0 12-17-2005 12:33 PM
