Old 01-29-2009, 06:47 PM
contractdesign is on a distinguished road
CNC Bridgeport whatever model servo upgrade
Question, I upgraded a Bridgeport boss 5 machine with steppers to a Mach 3 and gecko drives. The machine has been running great for two years, perfect. I would like to do another upgrade with to an older Bridgeport with servos using the same upgrade equipment, Mach 3 and Gecko drives. I am skeptical about a Gecke / servo upgrade. Gecko says that theor drives will work with servo permanent magnet motors. Has anyone out there done this and I would your feedback. I am well aware of the advantages of servo vs. stepper drives. I am just trying to fond out if I can succesfully upgrade a bridgeport, that I do not have yet, with Gecko drives and a Mach 3 system.
Bridgeport Upgrade jaztau Bridgeport and Hardinge Mills 12 11-13-2008 08:54 AM
Bridgeport Series 1 CNC upgrade / retrofit chrispy Vertical Mill, Lathe Project Log 4 11-06-2007 03:54 PM
MiLBOT Marker Plotter 2.0 (Upgrade model) muzzammil1444 Open Source CNC Machine Designs 9 03-04-2007 02:19 AM
Bridgeport TNC150 to TNC151A upgrade UK Dave Bridgeport and Hardinge Mills 9 02-13-2007 09:42 AM
Best upgrade to 2 axis CNC for bridgeport mill? mbwittig Bridgeport and Hardinge Mills 1 10-23-2006 07:59 AM
