Old 01-24-2009, 05:01 PM
bk1955 is on a distinguished road
Interact 1 MK ll KTK Spindle Drive
This is a low hour machine (Heidenhain TNC 2500 Control)that had been in storage for awhile. I have been working on it for several months. I finally got everything working and on my second program I found that the spindle is dropping out if I try to run above around 1200 RPM. It tries to start and then stops, the machine will continue on as if it is running. There is a small square reset button on the board that kicks out. I don't know if that means anything. I have read that these don't have a great reputation. When I got the machine and started it for the first time, a resistor burned up on the MTI-1 board, I got that repaired and I had programmed spindle speeds above 1200 since then. Is there any tuning or troubleshooting that can be done? Anyone have any documentation?
Thanks for any help.
brad@highlandmachine.com
bridgeport interact 4 spindle drive 0041601 Bridgeport and Hardinge Mills 34 02-09-2012 03:33 PM
Need Help!- Interact spindle drive Jhowes Bridgeport and Hardinge Mills 4 12-01-2008 02:28 PM
interact 4 spindle drive won't turn on spindle 0041601 Bridgeport and Hardinge Mills 7 06-23-2008 05:51 PM
Interact 412, Spindle Drive JoshG Bridgeport and Hardinge Mills 1 03-25-2007 03:48 PM
HELP..retrofit interact 4 spindle drive? camarogod98 Bridgeport and Hardinge Mills 7 01-22-2007 04:12 PM
