| Hi everyone...does anyone know how to do actual tapping on the Bridgeort series 1 tnc 145, the programing manual has one brief discription with some programe lines but in theory there must be more to it because i tried it today and the going in was sort off ok but how to get the tap out again?? Any advice will be appreciated. |
LLoyd <G> |
LLoyd |
Well, the implication was that he already HAD executed a tapping maneuver (um... half of one, actually <snicker>) So, then: Since he doesn't understand the maneuvers necessary to back the tap out, there's another solution a person like him could use -- He could install a honkin' big contactor with enough contacts so that he can reverse the spindle AND the Z-drive all at once. Then he could back out with the same code he used to ruin the work in the first place. Or, he could just slam the X-drive to high-speed slew, and run that tap out sideways. It even works with BIG ones! ('seen _that_ done before! <G>) LLoyd |
Would it have been more constructive to tell him to eshew tapping under power, and hand-tap all his holes? Some questions are legitimate. Some must be trolls. When a guy asks you, "If I downfeed, and run the spindle clockwise to thread in a tap, how do I get it back out?", you have to either tell him in deeply controlled fashion how to apply up-feed and run the spindle widdershins, OR you treat the question like the troll it must be, and give him a "shop" solution. Besides... admit it. YOU'VE seen guys hand-cobble G-code to "remove" taps sideways, too; haven't you? (and weld spanners to benchtops, etc...) All in fun. I just couldn't take the question seriously. When he told me I didn't understand anything about machining, the Devil made me do it. LLoyd |
| So why do they say in Programing manual that it can be done, it is actualy on of the 6 quick programing cycles?...i managed to programe the downward tapping cycle by following the manual sample but they dont say how to reverse... |
#11
| because it doesn't reverse, it assumes you are using a tapping head. no input on control for spindle encoder no encoder on spindle means no rigid tapping. the tapping cycle[note it is not rigid tapping] is just a slow in slow out cycle, where a drill is slow in rapid out |
#12
| Gus maybe i must start this whole thread from the begining because it seem my machine might be to old for some off the members of this forum...I have the Interact series 1 proraming manual in front of me..in this manual they say that you can tap with a ¨Fixed programming cyle¨there are 8 cyles, and tapping is cycle 2...with the example in the book the tap only goes in....so GUYS!!!! all i want to know is how to reverse the whole setup...is this such a dificult question? |
| Tapping head or rigid tapping | Gregory_C | Syil Products | 2 | 10-18-2008 12:49 AM |
| Rigid tapping or tapping head | wildcat | Industrial Hobbies (Support forum) | 7 | 09-24-2006 12:08 PM |
| What is the Difference between 6000 series aluminium and 7000 series | Kosta1234 | General Material Machining Solutions | 3 | 11-19-2005 08:04 AM |
| tapping head vs hand/cordless tapping machine.... | InspirationTool | General Metal Working Machines | 6 | 09-12-2005 08:10 PM |
