| I have a late 70s early 80s series 1 bridgeport boss 5 cnc, not sure what year. I have run it off a three hp phase converter for about threee years until now. I started the converter up and then the machine and immediately came up with the dreaded 70007 error. I was wondering if anyone has ever recovered from this error or found some way to fix it? I am told the lsi11 board is probably bad but im not sure yet? The spindle starts but i have no axis motion control. I have also checked, cleaned, reseated, and pressed the chips on the card but to no avail. I have all the original manuals and circuit diagrams but it doesnt help much cause i took out the tape reader in favor of pc programming and loading. any help would be appreciated. thanks |
| Probably LSI-11 AKA a Digital Equipment Co Kd11L board. Google this board. Check logic supply. Fan beneath boards. What LEDs are lit on front panel? George
I finally got my internet going again to respond to threads. The knowledge you guys have is greatly appreciated. I pulled the lsi board out and cleaned it again but to no avail. I checked the voltages at the blue and lavender wires and found they were almost right on, only off by about +-.10 volt. I didnt think this would cause the problems associated with the lsi board but i adjusted them to be right on anyways. When you power up the machine the goto, hold, f, s, and t lights are on but you cant do anyting with the machine. When you hit the red reset button the air brake resets and then you can start/stop the spindle but thats all. any info would be appreciated or if i should be looking for a new type of controller. thanks |
I just got a series 1 cnc and I have the same 70007 error. I was messing with the reset, clear, and load switches by the tape reader, then the alarm went away. I got the spindle to turn on, but could not get x,y, or z to move. So I powered it down, turned it back on and I could not get the 70007 # to clear.? |
Hi: I have a bridgeport series 1 2 hp cnc mill which I am trying to get up and running. Circa 1980 We have connected the machine to the computer using a RS 232 kit and software purchased on the internet. After connecting to the machine and downloading the software, we are able to communicate with the machine. This is not a retrofit to new controls, we intend to use the Boss 5 system installed in the machines computer. We ran a sample program which came with the software and the machine ran throug the cycle just fine the first time. If I repeat the process, the machine only runs the first line of code and stops. Your thoughts and comments will be greatly appreciated. Thanks Andy |
| bridgeport boss 8 | AdamD | Gecko Drives | 2 | 11-17-2009 12:30 PM |
| Problem- Boss 8 Bridgeport problem | snovak240 | Bridgeport and Hardinge Mills | 6 | 10-22-2008 09:47 PM |
| bridgeport boss 4 | jodybo | Bridgeport and Hardinge Mills | 0 | 02-25-2008 09:19 PM |
| bridgeport II/r2e3 boss 8 | whaley | Mechanical Calculations/Engineering Design | 0 | 01-01-2008 11:02 PM |
| bridgeport series 1 boss 6 | MR Custom | Bridgeport and Hardinge Mills | 11 | 11-19-2007 07:04 AM |
