I have an interesting problem on Beaver mill with a TNC145 control. If you try to reference the Z axis it runs to the home switch, reverses and finds the index as it should. Once it finds the index it then runs away at full speed and trips out a gross positioning error. The same happens with the Y axis but not X. I swapped Z and X encoders with no effect. I have also swapped the axis drive boards. Anyone seen this before? |
| The machine was running fine then the Y axis ran away and tripped with a 'gross positioning error' halfway through a job. Now whenever you try to reference it runs away then faults immediately after referencing. I can't see it being a drive problem as it is perfectly controlled while referencing. Once it has faulted out, if you manually move the Z axis you can see the Z position display changing so the encoder appears to be working. |
| Z axis homing problem | BillTodd | LinuxCNC (formerly EMC2) | 4 | 08-26-2008 02:55 PM |
| EZ-TRAK SX II homing problem HELP! | guitarist1904sd | Bridgeport and Hardinge Mills | 5 | 08-04-2008 09:08 PM |
| Just another homing problem | jeffrey001 | DIY-CNC Router Table Machines | 2 | 05-31-2008 07:18 PM |
| Problem With Homing X Axis | elalto | Mach Software (ArtSoft software) | 1 | 09-15-2006 07:28 PM |
| Homing Problem V4.0.1 | BMaynard | TurboCNC | 5 | 04-13-2006 01:22 AM |
