Old 01-14-2009, 10:21 PM
jamescrowe is on a distinguished road
r2c3 y-axis bearing source
i recently aquired a series 1 cnc r2c3 project as a conversion, the mill was partially dissasembled and i cannot find the y-axis ballscrew support bearing set pn#1-115-0271. they are available new but pretty expensive. i was curious if anyone on here knew of another source, or possibly a used set.
thanks for your input
james
Old 01-15-2009, 03:10 PM
gus gus is offline
gus is on a distinguished road
re
They are a matched pair of IIRC angular contact bearings. They should be the same for all that vintage CNC machine. They will not come super cheap. If someone has their machine apart they can give you the bearing numbers, I do not think they are bridgeport specific
Old 01-16-2009, 01:54 AM
thanks gus, i was hoping someone might have or know of a parts mill, or had the bearing numbers, i wouldnt think they were bridgeport only
james
Bridgeport R2C3 manual ps2727 Bridgeport and Hardinge Mills 9 10-09-2010 08:08 PM
r2c3 troublewith switch Dar Bridgeport and Hardinge Mills 2 08-24-2007 04:09 PM
New member, considering a R2C3 with a TNC 145 control Any help is appreciated snafu350 Bridgeport and Hardinge Mills 4 08-18-2007 09:46 PM
V-Groove Bearing Source needed widgitmaster Linear and Rotary Motion 20 03-31-2007 11:42 AM
Need a source for this bearing mount/assembly SteveL Linear and Rotary Motion 2 09-17-2006 07:43 PM
