Old 01-11-2009, 12:40 PM
kewl_cat is on a distinguished road
Series 1 Spindle Vibration / Chatter
I have a Series 1 w/Erickson 30 quick change doing fairly light work cutting aluminum. Fast or slow RPM or feeds the result and sound is the same. 3/4 or 1" end mills seem to make no difference. I have tried a new quick change end mill holder, different end mills, up/down milling. Climb milling does produce a little better finish but not like I am used to. I even had one of my machinist friends help me and he said he thought there was a mechanical problem and not a feed/speed problem. It does make slightly better cuts at very slow RPM under 1000. But still fairly nasty looking cutting for a mill. I took the spindle out and it did not see anything apparent. I did tighten it 1 click on the nut with no change. I did notice it had Fafnir M206KDD and M207KDD bearings. I was going to just change them from a local bearing supply house but my machinist friend told me they are specially cut to put preload on them?? Any ideas or suggestions??
Old 01-11-2009, 01:29 PM
Moderator
machintek is on a distinguished road
NC CAMS has posted a lot of data on these spindle bearings. Search the posts.
George
Newbie- Screw vibration and chatter tfrisbie Want To Buy...Need help! 0 01-04-2009 10:05 PM
Spindle bearing chatter befunovo Industrial Hobbies (Support forum) 9 12-23-2008 04:43 PM
Need Help!- Chatter vibration issues Designsync DIY-CNC Router Table Machines 2 02-15-2008 05:10 AM
spindle fan vibration on mini mill 1ctoolfool Haas Mills 1 04-26-2007 07:31 AM
Chatter marks and heat on a series 1 Andyh Bridgeport and Hardinge Mills 9 08-16-2005 08:24 AM
