Old 01-10-2009, 09:55 PM
HimyKabibble is on a distinguished road
Taking A Poll: Speeds And Feeds
All,
I've spent countless hours finding as much information as I can, and being amazed at how little agreement there is, even across manufacturers. I see SFPM numbers from 200 to 600, chiploads from 0.001 to 0.006. I know my machine (a BP clone) is quite happy roughing with a 2-flute HSS endmill at 3200 RPM and 10-12 IPM with a 0.5" DOC and mist coolant. This gives me a good finish, long tool life, etc. But, calculations show I might potentially be able to run considerably faster than that (well, assuming enough spindle power). Would I be better off going to 1" DOC and 5 IPM? Or maybe 0.25" DOC and 25 IPM? Or faster? I haven't done a huge amount of experimentation (though I plan to over the next few days, so I expect to "sacrifice" a few tools to the Gods of CNC....).
I'm just curious what other people use. I understand there will be variation machine-to-machine, but I think it would be interesting to see what the spead is. So, suppose you want to rough out a 1" deep pocket in 6061, using 1/2" HSS tooling. What tool would you use (2-flute? 4-flute rougher?), at what RPM and what feed? Assume coolant.
Now, how about same question, but using a 1/4" tool instead? And 3/4" tool.
This should be interesting....
Regards,
Ray L.
Old 01-10-2009, 10:53 PM
RMR RMR is offline
RMR is on a distinguished road
1/2 3 flute Y/G alupower 55 ipm 7500 rpm 1/2 doc. 1/4 3 flute Y/G alupower 24 ipm at 7500 rpm .25 doc
Old 01-10-2009, 11:20 PM
CarbideBob is on a distinguished road
7500 rpm on a B-port clone?
That would be interesting to watch.
Bob
You can always spot the pioneers -- They're the ones with the arrows in their backs.
Old 01-11-2009, 12:05 AM
The 7500 RPM really surprises me! That's over 900 SFPM. I see that's a "powder metal" tool, which I have no experience with. That's 0.001" chipload, which is surprisingly light, especially for a rougher. Are you limited by spindle power under those conditions? What kind of tool life do you get with that?
Regards,
Ray L.
Old 01-11-2009, 12:07 AM
Bob
I run my Taiwanese BP clone up to 8200 RPM (5440 RPM rated speed + VFD cranked up to 90Hz). It doesn't seem unhappy there. The spindle gets warm, not hot, after a couple of hours of continuous running.
Regards,
Ray L.
Old 01-11-2009, 08:55 AM
RMR RMR is offline
Smile
I have a HAAS VF1 and an HL10, I can get away with 100 ipm on the 1/2 Y/G but with only .25 doc because of HP at that rpm . The 1/4 Y/G I have gone as high as 40 ipm. Those other #'s were safe # to last forever.
Old 01-11-2009, 09:48 AM
Very impressive! Care to hazard a guess what you could get away with using standard HSS 2-flutes?
Regards,
Ray L.
Old 01-11-2009, 09:55 AM
RMR RMR is offline
I don't buy HSS end mills because I can buy the Y/G's for such a good price I don't even mess with regrind. The 1/2 Y/G is around $26 to $30 and if you take care of them you will make good money with them.
Old 01-11-2009, 09:57 AM
Wow! Where do you get them for that price? The places I've seen they were twice that.
Regards,
Ray L.
Old 01-11-2009, 03:53 PM
Come on, guys! I know there's more than two of us cutting aluminum! Let's have some more feedback.
I just spent some time playing, and testing different feed rates. Here's what I found (all in 6061, using heavy mist coolant) the limits to be, before clogging or other bad things happen:
1/2" HSS 2-flute - ~15IPM for deep slotting (1/2" DOC) at 2500 RPM. So, my 10-12IPM typical rate seems about right.
1/2" HSS 2-flute - ~25IPM for shallow slotting (1/4" DOC) at 2500 RPM.
1/2" HSS 4-flute rougher - ~20IPM for deep slotting (1/2" DOC) at 2500 RPM.
Pretty darned amazing how far a 1/2" endmill will bend when it clogs and stops turning during a fast feed!
I gotta find me some of them YG1 "Speed Freeks"....
Regards,
Ray L.
  #11   Ban this user!
Old 01-11-2009, 04:17 PM
RMR RMR is offline
Smile
I buy most of my tooling at Triad Tools in Colorado, I think the city is Arvada.
303-424-3006 Don't quote me on tooling because it has been about three months since I bought 1/2 inch end mills.
  #12   Ban this user!
Old 01-11-2009, 04:18 PM
RMR RMR is offline
Remember that the speeds and feeds I talked about are with flood coolant not spray mist.
Feeds and Speeds tac8357 Mentors & Apprentice Locator 1 06-26-2008 09:50 AM
Speeds n Feeds jessbussert WoodWorking 12 06-12-2008 11:09 AM
speeds and feeds bdrmachine SolidCam 6 04-12-2008 08:15 AM
Speeds and Feeds CLP CORP. WoodWorking 16 12-07-2007 12:38 PM
feeds and speeds lito General Metalwork Discussion 4 03-14-2005 07:58 AM
