Old 01-08-2009, 03:10 PM
jbwooten is on a distinguished road
axis error on BP R2E4 Boss 9 Mill
How do you check the resolution setting on this mill? The x,y,& z axis all seem to be off the same amount. This error gets larger the farther you move each one. It has the metric screws. Any advice on how to adjust this would be welcome!
Old 01-09-2009, 07:27 PM
Moderator
machintek is on a distinguished road
There used to be a tag/label on the inside of the side electrical panel as to what boards should be in your machine. It would say it is a metric board vs a inch board. I would check to see if the part number of your FMDC matches this label.
No adjustment for the pitch error.
Only backlash comp.
George
Series I R2E4 BOSS-9 manuals, where get? lloydsp Bridgeport and Hardinge Mills 2 01-06-2009 05:50 PM
BOSS 8 random axis limit error rkdygert Bridgeport and Hardinge Mills 12 03-17-2007 12:03 PM
Power for R2E4 Boss 9? dfstrasser Bridgeport and Hardinge Mills 1 12-13-2006 08:18 AM
Bridgeport CNC Mill, Model R2E4, Boss 9 Control Tbucit Bridgeport and Hardinge Mills 5 03-17-2006 09:39 PM
