Hi There, I have an old Horizontal Bridgeport machine with power feed. The machine was made in Leichester England and the sequence control panel was built by Saunders Electronics Limited. The X-axis limit switch box was connected wrongly, therefore the machine won't come on. There are 11 wires that I do not know where to put - wires are numbered as follows: 185, 186, 187, 188, 189, 190, 56, 20, 11, 12, 159, 17 I opened the y-axis and z-axis limit switch boxes and wires were connected as follows: Y-axis: 21-20 normally closed - Hard limit 51-50 normally closed 50-41 normally closed Z-axis: 21-22 normally closed - Hard limit 51-52 normally closed 52-46 normally closed I assume that the x-axis should be : 185-186 normally closed 187-188 normally closed 189-190 normally closed wires 17 and 159 is connected to the emergency stop (17 comes from the machine and does not connect to the limit switch box - where 159 has to connect there somewhere. The emergency stop switch is normally closed and when I activate the contactor it has 110V to ground. When the contactor is activated 185-186 has 110V to ground. This leaves me with wires" 56 20 11 12 159 Could you please help me....I need this machine running. Kind Regards. John |
| THC Schematic | Bostjan M. | CNC Plasma and Waterjet Machines | 1 | 06-22-2008 07:35 AM |
| Need Schematic/Information for Bridgeport Textron DRO | hwerner | Bridgeport and Hardinge Mills | 3 | 02-15-2007 02:03 PM |
| Bridgeport Retrofit Wiring Diagram | UKRobotics | General Electronics Discussion | 0 | 09-18-2006 04:39 AM |
