Old 12-22-2008, 08:08 AM
colin1544 is on a distinguished road
Series 1 cnc drive belts
Hello I wonder if anyone over on your side of the pond has a supplier for the X axis toothed timing belts for a series 1 Boss 5 cnc machine I am having a bit of movement problems and want to try a new belt as the present one has been well soaked in oil over the years and I think it is stretching when doing small moves, as when I try do set up using half thou moves it tends to hold and then jump about 1 1/2 thou. thanks Colin
Leather drive belts Randy Stevenson General Metal Working Machines 2 05-16-2008 06:50 AM
belt drive conversions - why v belts? cnc-newb Benchtop Machines 39 02-28-2008 09:10 AM
Can G320 drive 2 motors in series? pixpop Gecko Drives 4 02-05-2008 06:13 PM
VFD drive Faults on series I cnc Bridgeport colin1544 Bridgeport and Hardinge Mills 3 09-22-2006 05:36 PM
Belts versus Direct Drive bsmith DIY-CNC Router Table Machines 12 06-06-2004 10:09 PM
