Old 12-20-2008, 07:04 PM
KTD1 is on a distinguished road
Question Tram a bed mill?
The spindle on my 760/22 is slightly out of square to the X & Y travels. It’s not a lot but leaves an annoying little step when facing with a 5” face mill.
Has anyone ever adjusted this? Is there an way to re-square the spindle of a bed mill?
George?
Old 12-21-2008, 02:24 PM
Moderator
machintek is on a distinguished road
Two ways to do this. The hard way is to rscrape the bottom of the head so the spindle fits in such a way that it is square to the table.
When we installed these machines, we used the back 4 leveling screws to adjust the column to the table so the spindle was square to the table.
Try that first.
George
Old 12-21-2008, 05:43 PM
Thanks George. I will try the leveling screws.
I'm thinking it's time for a little gib adjustment on the Z as well. I've noticed a little (0.0003") movement on my indicator when moving the Z up and down.
Any words of wisdom on Z axis gibs?
Old 12-21-2008, 07:02 PM
Moderator
The Z axis is difficult. I recently was called in to see why a customer was losing his finish on a Daewoo VMC. X and y checked out great.
Using a pile of indicators and a bottle jack, I determined that the z was rocking side to side but not front to back. We are talking less than a thou side to side.
This gib had a spacer that I had to grind down to get it to where I wanted it. The trick is not to get it too tight.
Assembling CNC horizontal boring mills is a chore! Takes me about 5 weeks. Makes a VMC look easy. And the customers expect these to be square within a few tenths of a thou too.
George
Howto Tram X4+ Head?? john_t_h Syil Products 7 11-14-2008 08:39 AM
head out of tram on BMC20 JWC HURCO 7 09-28-2008 09:44 AM
Digital Angle Finder to Tram Regnar Benchtop Machines 2 09-15-2008 01:29 PM
Taig Y is out of tram... sp1nm0nkey Taig Mills & Lathes 1 12-15-2007 05:13 PM
Rust and tram Vern Smith Haas Mills 5 06-26-2007 06:22 PM
