Old 12-17-2008, 02:59 PM
hmc710 is on a distinguished road
TNC 145 DOUBLE AXIS ERROR - FOUND
..... AND SAME ERROR: AXIS DOUBLE PROGRAMMED. LOOKS LIKE CODE 358 BUT HARD TO READ.....
WHAT A NUB! I KNEW THE DOUBLE AXIS WAS USUALLY A PROGRAM ERROR TRYING TO GO TO Y 1.4 , Y 2.3 FOR EXAMPLE BUT THIS ERROR DIDN'T STOP AT THE BAD LINE, BUT A FEW BEFORE IT. PERHAPS THE ERROR "CODE" WAS ACTUALLY THE LINE NUMBER?
THANKS FOR KEEPING THE WISE CRACKS TO A RESPECTABLE MINIMUM!
Old 12-18-2008, 12:12 PM
gus gus is offline
gus is on a distinguished road
re
Yes, it should say AXIS DOUBLE PROGGRAMMED 22 or somesuch, 22 being the line in question IIRC, It does have look ahead.
Old 12-18-2008, 01:13 PM
Thanks Gus
Thanks for the reply Gus, I appreciate it. You are correct!
By the way, could you help me get this thing hooked up to a pc so I can off line edit programs? I've tried a number of different cables and programs from Heidenhain and other DNC's and have not had any success. Thanks for any help you can point me to.
New 6-axis Double-Closed-Loop Controller? brccrb Product Announcements & Manufacturer News 28 03-04-2009 09:46 PM
Need Help!- Double x axis drive mrfreon DIY-CNC Router Table Machines 13 02-21-2008 06:03 PM
How to drive double x-axis? zone023 Open Source CNC Machine Designs 5 04-01-2007 04:35 AM
Y axis rail- single or double? Corvus corax Linear and Rotary Motion 5 11-15-2005 06:42 PM
Double X-axis Drive mícheál DIY-CNC Router Table Machines 4 11-15-2004 08:48 AM
