Just thought I'd say hi. I just purchased a SeriesI 3axis mill (yr=2000) for $1600 and will be in the process of changing it from a 460V configuration to 220V configuration. I intend to power it with a 5hp rotary phase converter. I'm not real sharp on the electrical so any advise would be welcome. Thanks, Steve |
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Thanks for the reply. It is a CNC which is why I was leaning toward a 3 phase converter. I have rewired the motor from 460v to 220v, changed the jumpers on the transformer, and and made an adjustment on MO1 to 7.4 amps. I am wondering if I need to change out the CR1 relay from 460v to 220v as well? Thanks, Steve |
![]() Sounds like you got a good deal on it, throw some power to it and make some $$$! most relays have a pretty broad input range. I would just try it unless you already have a 220v relay, then I would probably swap it for the sake of doing things correctly, but honestly, wouldn't suprise me if the 440 relay kicks fine under 220 power. |
| There are 2 factors to consider. The coil voltage. Hopefully it is not 440V. Secondly the current the relay can tolerate. If you go from 440 to 220 V then typically the current doubles. Hopefully the contacts are rated for that. George
| Problem With Newly Draw Software- Please Help !!! | hubery | Laser Engraving & Cutting Machines | 5 | 03-01-2011 09:23 AM |
| First part made on my newly CNC'd X1 :) | Memran | Benchtop Machines | 13 | 04-29-2007 06:48 PM |
| Just aquired first mill a Comet 3KV. | Jack F | Knee Vertical Mills | 11 | 10-01-2006 12:41 PM |
| My newly repaired B&S Indicator is here! | widgitmaster | Calibration & Measurement | 4 | 08-05-2006 12:03 PM |
| Any help for a newbie? | Jounik | General CNC (Mill and Lathe) Control Software (NC) | 12 | 01-12-2005 10:12 AM |
