I've bought a bridgeport which has the 2J head and a dual voltage 1.5hp motor. I've now got an invertor to allow me to connect up and use 240 three phase. Question is where on the machine to I have to swap over the electrical links from star to delta, i've tried to access all elec boxes i can find but i can't seem to find this electrical connection? Also do i need to do the same with the x axis motor? Any advice appreciated. Thanks Jamie |
| In theory, unless you have a NFPA cabinet, the X power feed is plugged into the wall outlet (115 VAC). The spindle motor voltage is done by the configuration of 9 wires in the small electrical connection box on the side of the spindle motor. George
| George ah ok.. Is this the box you are referring to? All the wires are numbered and are as follows: Wires 1,2&3 come from motor and connect to other wires which go to switch box. All the other wires are grouped 7&4, 8&5, and 6&9. Can you advise on which cables I need to re-connect? Also the second pic is where the x axis motor cable enters the main elec box, it comes via the control box on the front of the machine. Will I need to alter anything of these wires? Many Thanks Jamie Last edited by JQ_Quint; 12-08-2008 at 11:09 AM. Reason: added photos |
| This should give you what you need: http://www.patchn.com/index.php?opti...d=44&Itemid=34 Regards, Ray L. |
| Ray, Thanks but i'm still not sure what I really need to do? Apologise if I sound a bit dumb, but electrical jargon not really my thing. Would you mind spelling it out exactly what I need to do.... Thanks J. |
| is connect the inverter to those three wires that leave the junction box in your first photo. I would *strongly* urge you to find someone local who understands this stuff, and can take a good look at what you've got, and what you're trying to accomplish, and tell you how to do it right. Making a mistake here can be expensive if you're lucky and hazardous to your health if you're not. Regards, Ray L. |
| Bridgeport Interact 1 MK2 - Input Voltage | palikalsi | Bridgeport and Hardinge Mills | 20 | 11-07-2008 07:42 PM |
| Is it really needed? Arc Voltage Torch Height Control | schoobie | Torchmate | 19 | 10-04-2008 10:11 PM |
| Dual Z axis and Dual Spindle | Adamj12b | Mach Software (ArtSoft software) | 3 | 08-28-2008 03:15 PM |
| Bridgeport EZPath help needed! | VSMIGuy | General Metal Working Machines | 1 | 01-08-2007 05:58 PM |
| Bridgeport Power Supply - what voltage? | damae | Bridgeport and Hardinge Mills | 3 | 02-03-2006 04:13 AM |
