Old 12-05-2008, 11:26 PM
zoeper is on a distinguished road
Fitting a VFD to a Bridgeport mill
Can anyone fill me in on the pro's and conns of fitting a bridgeport type mill with a VFD?
I suppose that low speed torque would be sacrifised, but how feasable is it?
My controll (Anilam crusager G)outputs a analog voltage to controll speed and at present it is hooked up to a motor and "controller" board that changes the handwheel on the head. it is slow to opperate and only acurate/ repeatable to about 30% of the programmed value. The analog signal should be easy to hook up to the VFD though.
Thank you
Pieter
Old 12-05-2008, 11:46 PM
Some of the gains should be the ability to ramp up the speed and to brake the motor without mechanical means. (i like this one)
and a simplified drive train doing away with the variable pulley system. This might make higher speeds possible.
Any comments welcome
P
Old 12-06-2008, 05:57 AM
TOTALLYRC is on a distinguished road
VFD bridgeport.
Thank you
Pieter
I have a hitachi sj200 sensorless vector drive hooked to my bport btc-1.
It came from the factory with an early vfd and a 2 speed gear box along with a 3hp motor. The sensorless vector helps with the low speed torque and is the way to go in my opinion. I am working on integrating the 2 speed to be controlled by Mach3. As it is now, If I have to go into low gear, I have to do it manually.
See my build log here. http://www.cnczone.com/forums/showthread.php?t=66994
There has been some discussion that the gear spread is too wide to work properly but so far it is working well for me, not that I have done much maching with it yet.
Old 12-06-2008, 09:59 AM
HimyKabibble is on a distinguished road
Thank you
Pieter
Pieter,
I see no cons whatsoever. You will lose torque at lower RPMs, (below perhaps 30-40Hz), but you can also run to as much as 200% of base speed. Overall, it will greatly reduce, though not eliminate, belt changes. You'll still need to change belts when going to very high or very low speeds. I have a Teco FM50 (under $200) on my 3HP BP clone, and love it.
Regards,
Ray L.
Fitting a Mill into a 2 car garage heepofajeep General Metal Working Machines 4 11-16-2007 07:15 AM
Re-fitting a mill gunner312 Benchtop Machines 1 07-11-2007 09:31 AM
What Mill? Bridgeport or... Com General Metal Working Machines 3 12-26-2005 04:48 AM
cnc fitting a bridgeport MBG Bridgeport and Hardinge Mills 5 09-26-2005 04:25 PM
What is the easist way to go CNC on a bridgeport mill. srbliss Bridgeport and Hardinge Mills 2 07-25-2005 08:24 AM
