Old 12-01-2008, 09:16 AM
spock is on a distinguished road
series II interact 4 acting up!
I have a BP series II interact 4, TNC 150 control
I was milling some 1.75 hex flats on some alum, noticed an issue. When I measure across the flats, they are all different from one side to another, one set consistently off about .006.
My guess is that x-y are not "tuned" if that is the right word. I havent tried one, but if I milled a circle, I bet it would not be very round.
So, can I adjust this out using the parameters? Or some other method?
Cant make this code run properly ganderboy G-Code Programing 11 10-30-2008 04:36 AM
Need Instruction On Properly Lifting A KMB-1 jalessi HURCO 0 07-31-2008 02:28 AM
motors not operating properly tee2 Automation Technology Products 1 01-11-2008 11:34 AM
Lazycam Not working properly for me? jstevens Machines running Mach Software 3 07-06-2007 02:00 AM
Kcam not seeing ovals properly monkamarm2000 General CNC (Mill and Lathe) Control Software (NC) 9 06-30-2005 02:40 PM
