Old 11-27-2008, 08:00 AM
dazzer is on a distinguished road
Ramping down
I need to ramp down in a circle pocket using a Heidenhain 155 control.
The existing plunge cycle is damaging the tool (no centre hole)
The pocket dia is 37mm and the tool dia is 20mm the depth is 8mm
Old 11-27-2008, 09:45 PM
Kevin Taylor is on a distinguished road
Pocket trouble
Center cut tool? plung to the bottom then G79 around to the dia. needed in two steps one close to finish then a light cut to size What is the material and do you have coolant on it Good Luck Kevin
Old 11-28-2008, 07:26 PM
gus gus is offline
gus is on a distinguished road
circular interpolate in polar mode you can enter a z coordinate after the degrees, not in front of a machine, but something to the effect of
CP I1080 Z-.5 F100 R0........
Problem- ramping truefordlover1 BobCad-Cam 4 08-01-2008 12:28 PM
ramping on a arc binzer GibbsCAM 7 06-10-2008 08:38 PM
Ramping Into A Profile partsman DIY-CNC Router Table Machines 8 01-15-2008 05:30 PM
Ramping pauls BobCad-Cam 1 03-04-2005 03:49 PM
Ramping example? inthedark G-Code Programing 5 04-10-2004 08:53 AM
