Old 11-07-2004, 09:24 PM
MDA40 is on a distinguished road
BP Series 1 CNC- spindle won't turn on
Need help on my Bridgeport series 1 cnc. I finished a part on the machine and went to turn the spindle back on and it will not start. Everything else works fine. I read in the manual and all it says is to check lube level and its full and switch is working fine. Any ideas would be greatly appreciated. Thanks in advance.
Old 11-07-2004, 10:02 PM
Al_The_Man's Avatar
You will need the electrical schematic, what type of spindle? DC, AC, AC with VFD?
Does it have an overload on the contactor that needs resetting?
Al
Old 11-08-2004, 07:30 AM
Gold Member
HillBilly is on a distinguished road
Check the overload reset on the spindle contactor. It's usually on the upper left side of the rear box looking from the front.
Darek
Old 11-08-2004, 09:05 PM
Got it running. It was actually the switch. Should of looked at that first. Thanks for the info.
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 01:06 AM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 08:01 PM
Spindle choice - Glass CNC digital Machine Problems, Solutions , Wireless DNC, serial port 3 10-30-2004 12:37 AM
CNC Retrofit - Kit verses turn on and go MetDetect General Metal Working Machines 21 07-12-2004 11:06 PM
CNC spindle and fluid control replicapro General Electronics Discussion 0 06-22-2004 02:37 PM
