Old 11-13-2008, 08:09 PM
CATCH22 is on a distinguished road
Timing pulleys for retrofit?
Im just wondering if im using a 12 groove and a 30 groove timing pulley does it make a difference which one I put on the motor and which one I put on the ballscrew? I would think I would put the smaller one on the motor and the larger one on the ballscrew.But what would happen if I did it the opposite way?
Thanks Mike
Old 11-13-2008, 09:04 PM
Al_The_Man's Avatar
You will increase the maximum rpm of the ball screw but decrease the torque by the ratio factor, also the inertia ratio will be increased by the square of the increase.
Old 11-14-2008, 05:43 PM
Im not planning on doing this I just wanted to know what would happen if I did.
Thanks for the reply.
GT2/GT3 timing pulleys supplier interflexo Mechanical Calculations/Engineering Design 11 08-08-2011 11:12 AM
i want to cut timing pulleys , so help !! max_imum2000 General Metalwork Discussion 18 08-08-2008 12:16 PM
Timing belts and pulleys? Jack Aubrey Linear and Rotary Motion 11 01-12-2008 04:41 AM
Timing belt and pulleys samakthachai Laser Engraving & Cutting Machines 8 10-24-2007 11:31 PM
Timing Pulleys h_2_o Benchtop Machines 7 02-02-2005 10:26 PM
