Old 11-13-2008, 08:33 AM
bherr is on a distinguished road
Question CAT40 vs BT40 tool holder????
Quick Question!!
Looking at a spindle speeder that has a CAT40 tool and I have a Bridgeport Series II Interact 4 that uses a BT40 tool holder. Are they interchangeable??
Need answer ASAP--thanks
ben
Old 11-15-2008, 11:27 AM
gus gus is offline
gus is on a distinguished road
re
I depends
different thread, different drive keys, slightly different length
I have done it on my VMC, but it depends what you are doing
Old 11-15-2008, 03:32 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Usually the biggest issue with interchanging is the ATC.
An ATC holds the tools by the flange groove and they are different there. Most machines will handle both tools if the correct pull stud is used.
IMO if you are already tooled for BT, I would stick with it.
You can get speeders with BT setup.
www.integratedmechanical.ca
Old 12-05-2008, 12:42 PM
My Bridgeport uses the BT40 and I'm trying to buy a used spindle speeder that is CAT40. If the only difference is the pull stud, can't I just purchase the different pull stud??
Ben
Old 12-05-2008, 12:55 PM
cnc4tr is on a distinguished road
bherr,
The taper for CAT & BT40 are identical 3 1/2" per foot.
The BT uses a metric pull stud thread 16mm X ?. The CAT is 5/8-11.
I'm not familiar with your machine. I don't know what a speeder spindle is. A quick change spindle I assume?
If you do not have an automatic tool changer, you can interchange the tool holders provided that the correct pull stud geometry is offered.
Look through MSC, or one of the other industrial supply catalogs to determine if you can get the correct pull studs.
Jim
Old 12-05-2008, 01:13 PM
Originally Posted by cnc4tr View Post
bherr,
Jim
Jim,
I contacted the manufacturer of the spindle speeder, which can increase the speed of the spindle by up to 5 times.These are used for mostly engraving. According to the sales rep I spoke with, she said the CAT40 and BT40 are completely different, but your saying the taper is the same, just the pull stud is different. I'll check out MSC and see if I can find something. thanks,
Ben
PS Don't want to spend the big bucks if it won't work. Just got off the phone with MSC support and they said they are NOT interchangeable and that the pull studs won't work, unless I rethreaded the CAT40.
Old 12-05-2008, 02:28 PM
USMCPOP is on a distinguished road
You might have a chat with Frank over at Martool. He makes pull studs and a lot of other tool holding stuff.
http://www.maritool.com/Retention-Knobs/c67/index.html
Old 12-05-2008, 02:35 PM
Ben,
O.K., I understand the speeder. Does this machine have an automatic tool changer? Years ago I had a series II Boss 6 Bridgeport. It had an Erickson quick change spindle...No Automatic tool changer.
My machine is a 1989 Leadwell with a 24 tool carousel. It uses BT holders. The pull stud geometry for my machine is available for the CAT tool holders.
I used a CAT floating tap holder without any problems. I just couldn't do a tool change because the BT and CAT tool clips are different. The flange at the top of the holders is different. I also have a Nikken probe that is CAT. It doesn't matter to me that it will not fit in the tool changer as I would never leave it in there anyway.
The taper and the guage line are the same. I am certain of this!
If you can get the right pull studs for the CAT holders, and you are not going to do a tool change automatically, I can't see any problems.
The bottom line is that BT & CAT holders do not universally interchange. For your application it may not matter.
I certainly do not want to give you a bum steer, so call around some more before making a final decision.
Jim
Old 12-05-2008, 02:47 PM
Ben,
Another note.
When I bought my leadwell I thought about converting it to CAT as they are far more plentiful on the used market.
I called Leadwell and they confirmed that the only difference was the carousel tool holder clips. The CAT pull studs work in my machine. Unfortunately these clips are $90.00 each, or about the same price as an average new tool holder, so I left it BT.
Jim
Old 12-05-2008, 05:29 PM
Moderator
machintek is on a distinguished road
The V groove on the hool holders is in a different position thus requiring the different fingers in the tool changer. ALSO the pull stud is different thus the inside of the spindle (drawbar) is different.
If you do not have a tool changer, just swap out the pull stud. I do not know what else the RPM multiplier has or needs, so be careful.
George
  #11   Ban this user!
Old 06-16-2010, 12:51 AM
ADARSHJEE ANAND is on a distinguished road
Question details of bt and hsk tool holder
please provide me with the details and specification of bt series and hsk toolholder series.
  #12   Ban this user!
Old 01-27-2011, 09:45 AM
zachwaldner is on a distinguished road
BT40 toCAT40
I had a problem using BT40 in a CAT40 spindle, they were loose . I took the retention knobs and machined them off above the thread .03 inch so they screw in farther and now they are nice and tight.
what is this tool holder for bassmastrbw96 CNC Tooling 1 09-06-2008 09:11 PM
BT40 holders in CAT40 machine? does it work... RedGTZ Bridgeport and Hardinge Mills 12 08-14-2008 11:08 AM
T slot tool post with drill bit tool holder brucesu1 CNC Tooling 0 06-09-2008 05:04 AM
Balanced CAT40 tool holders? rigo430 CNC Tooling 3 11-27-2007 07:51 PM
tool holder corrie DIY-CNC Router Table Machines 2 07-23-2004 04:04 PM
