I've recently completed a
CNC conversion on my BP clone, and it works great. I took the quick and lazy approach to the Z axis, by replacing the knee crank with a servo motor and belt reducer, leaving the bevel gears and leadscrew in place for now (to be replaced with a ballscrew at some point). A friend has an identical machine, so I made him a set of drives and other parts identical to mine, which he has just fitted. But, his machine apparently has a higher torque requirement on the knee than mine, and as a result, his knee does not work reliably. Mine is perfectly reliable, albeit not real fast, at only 25 IPM.
So, we're looking for options as to how to resolve the problem. Some things that have come up are getting a larger servo motor (currently 850 oz-in, with 4.8:1 reduction), getting a big stepper motor (2550 oz-in), adding gas springs, going ahead and converting to ballscrew, and eliminating the bevel gears, to reduce friction.
So, some questions for anyone who has experience with powered knees:
1) How have others done this? What is the most common drive configuration for powering the knee? What kind of motor? What reduction?
2) What kind of gas spring is appropriate? I bought a pair of 200 pound springs from McMaster (not yet mounted), and am surprised to find I cannot make them budge, even putting my full weight on them. Makes me wonder if they're TOO stiff.
3) Can a large stepper be used here? My impression is probably not, as given the high reduction (48:1), 1250 RPM would be required to even reach 25IPM. That seems high for a stepper, especially a large one.
4) Any other ideas or suggestions? Pictures/info of how others have done the knee?
Regards,
Ray L.
