Old 11-04-2008, 06:13 PM
AbsoluteMTS is on a distinguished road
Bridgeport interact series 1 axis run-away
Hi all, I have a bridgeport interact series 1 with a 145 heidenhain controller. After setting up all 3 axis, gain, offset etc. The machine ran fine all weekend, it was then powered down. Upon return on monday morning, when trying to reference the machine runs away in a positive direction. Even if its on the dogs instead of moving away and then referencing all axis shoot off in the positive direction. After a fashion I managed to get machine to ref. But if i select any axis and touch the joystick or mpg the relevent axis runs away in a positive direction. Any help much apprieciated.
Old 11-04-2008, 07:51 PM
Moderator
machintek is on a distinguished road
A axis will run away in all 3 axis if the control does not see it move. In other words I believe that the encoders are not being seen by the control.
First thought: 5 VDC to the encoder bulbs is not there.
2nd thought: control sick.
George
Old 11-05-2008, 06:48 AM
gus gus is offline
gus is on a distinguished road
definitely not seeing the encoders, this machine should never run away, should give a flashing error quickly.
Bridgeport Series 2 Interact 2 Heidenhain TNC 155 rrossey Bridgeport and Hardinge Mills 9 05-16-2011 08:29 AM
Bridgeport Series II Interact 2 problems gugu Bridgeport and Hardinge Mills 24 01-10-2011 07:34 AM
Need Help!- Bridgeport Series 1 interact tnc 145 jaztau Bridgeport and Hardinge Mills 2 10-20-2008 04:12 AM
Need Help!- Bridgeport Series 1 Interact zorba99 Bridgeport and Hardinge Mills 7 06-11-2008 07:59 AM
Bridgeport Series II Interact 4 Z-Axis Timing Belt UKRobotics Bridgeport and Hardinge Mills 5 01-04-2008 04:47 PM
