Old 11-03-2008, 09:28 PM
batterzazu is on a distinguished road
Series One Y axis Problem
I have finally found the time to start working on my Series One project again. Here is where it stands my Y axis will not jog. I removed the Acc board and removed all of the transistors and check them and they all checked out OK, I reinstalled them and now my X axis readout changes when I jog but the axis does not move, I then flipped the Acc board and now both X and Z jog just fine.
I expected to find that the z would not work correctly so now I am really confused.
Just for fun I wired the Y axis motor to the X axis to make sure I do not have a Y axis motor problem and it turns out that the motor worked just fine being controlled by the X axis.
Plan of attack, I think I am going to replace all of the transistors on the Acc board so I know that they are in fact all good and strong, the other thing I have read is to replace the screw in fuse holders with the snap in style so I will probably do that as well.
Please let me know if I am headed in the right direction.
Thanks in advance Scott
Old 11-04-2008, 07:04 AM
Moderator
machintek is on a distinguished road
With a 99% frequency, the problem is/are the final drive transistors, not the ACC board trannsistors. The ACC regulates the current through each drive with the saturable core reactors.
The usual transistors to blow are on pieces of aluminum with the transistor cans facing the door. There are 3 of these, Each holding 4 transistors.
George
Old 11-04-2008, 08:39 AM
Thank you George, what would cas my acc. board work inverted but not installed correctly?
Scott
PS I will find my final drive transistors tonight.
Old 11-05-2008, 08:24 PM
Question
Ok I found the final drive transistors for the Y axis, now I need to bring them to work to test them. If they are bad is there a replacment transistor and diode that would be more reliable?
Scott
BP Series 1 Tera Term problem mellery1 Bridgeport and Hardinge Mills 1 04-09-2010 03:53 PM
Series I Y axis voltage problem batterzazu Bridgeport and Hardinge Mills 2 09-30-2008 08:36 AM
BP Series 1 Z-axis problem (BOSS 4) ABT Bridgeport and Hardinge Mills 5 04-29-2007 07:32 PM
problem with BP series 1 spindle not working zoqdi Bridgeport and Hardinge Mills 0 02-06-2007 03:04 PM
Series 2 BOSS 6 Axis motion problem craig96us Bridgeport and Hardinge Mills 43 01-14-2006 11:06 AM
