Old 11-03-2008, 07:12 PM
sidstover is on a distinguished road
Eztrak X axis will not home
I have a 2001 Eztrak that worked fine before I moved it to my garage, now the x axis will not home but just slowly moves till it alarms out (X DAC underflow). Ive swapped the X and Y servos, no change. What can I look for?? Also does anyone have a wireing schematic.
Sid
Old 11-08-2008, 08:47 PM
doctordemo is on a distinguished road
Sid, I a no expert but I hav an z rack in my garage that has given me fits fro time to time.
Mae sur the table is unlocked and that your micro swich is not suck and that all connections are sound.
Steve
Old 11-09-2008, 11:28 AM
Thanks for the input Steve, I`ll check the switches today.
Sid
Old 11-11-2008, 05:57 PM
Moderator
machintek is on a distinguished road
Are the drives turned ON when they drift?
Usually a drift occurs when you lose the position loop and the balance of the drive is a bit off center. But a DAC underflow means that the control is seeing the encoders and they are moving when they are not supposed to.
I would be checking the 12 VDC which presence turns the drives off.
George
Old 11-11-2008, 07:04 PM
The X axis drifts when it tries to home but it will not home before it alarms out. I`ll check the VDC thanks.
Sid
Problem with my EZTRAK 3-axis Ingchema Bridgeport and Hardinge Mills 1 09-21-2008 01:47 PM
Problem with my EZTRAK 3-axis Ingchema Trade Shows and Events 0 09-16-2008 07:59 AM
Need Mastercam post for Bridgeport EZTrak DX 2 axis mill Mal@AMTS Post Processor Files 2 06-09-2007 01:26 AM
Ver 7.0 Eztrak 2 axis. Spindle wont turn MrMudd Bridgeport and Hardinge Mills 3 06-13-2006 01:18 PM
EZTrak with factory installed 3rd axis. Gncc50 Bridgeport and Hardinge Mills 2 04-08-2006 01:13 PM
