Page 1 of 3 123 LastLast
Results 1 to 12 of 26
Thread: Interact 1 MK2 MT1-1 board(KTK drive)
    Jul 2008
    Westfield, Indiana
    I have posted questions about his machine in the past. It is basically a new machine, it doesn't have a chip on it and I doubt it has been ran since it was initially delivered.
    I haven't been able to get back to it for a while but started looking at it again today. I had the power on and had zeroed the axis's then was interrupted for a bit. When I came back I smelled the dreaded electrical burning smell. Upon looking around I found that the MT1-1 board has burned up a few component's. I was told that there were problems with this board(transformer) and this should be the first place to look for problem I was having in getting the spindle to run.
    1)The easiest solution is to replace the board but are there any out there?it has a part number on it, 1551469
    2)Is there another spindle drive board that will work?cost?
    3)An electrical engineering type friend said he could probably repair it if I could find either a wiring diagram for the board or the identification of the big, round blue part just above and to the left of the transformer. I suspect the transformer will need replaced but don't have any specs on it either and it may be the hardest part to get.
    4) the components that appeared to get "hot" are3 and D4, maybe R24 and definitely the 3 components directly above them(toasted).
    Any ideas or other solutions to this "problem"?
    Thanks for all your help in advance, Brian
    Mar 2008
    I may have the same machine as this. Can you post a picture of the board and the area in question? Maybe I can identify the parts.
    Jul 2008
    Westfield, Indiana
    I was wondering if I could replace the KTK drive, (the MTI-1 board and what else needs replaced?) with the mentor drive, I understand they used those also and didn't have as many problems with them, as I said my board is toast and I am not having any luck finding a replacement or someone to repair it. I hate to toss out a machine that probably has less than 10 hours on due to this, any ideas? PLEASE HELP
    Attached Thumbnails Attached Thumbnails Interact 1 MK2 MT1-1 board(KTK drive)-151_5130.jpg
    Moderator
    Nov 2004
    You may want to pursue KTK help in the UK. There is none here in the US.
    Otherwise, you can call EMI. I believe they are selling spindle drives to replace the obsolete one. Just be sitting down when you hear the price. I recall that a Mentor may have been used on a 308. Interact 4 used a Contraves and then switched to the KTK. With an Italian motor. Go figure.
    George
    Jul 2008
    Westfield, Indiana
    I have been trying to persue help from the UK, still waiting for another reply. When I had been in contact with the service department over there earlier they emailed me some troubleshooting info, turned out it was for use with the mentor2 drive, that;s why I wondered about it.
    Not familiar with EMI? Is my best bet to just to sell it as scrap and cut my losses now?the machine is brand new, probably has less than 10 hours on it and never got past the initial run off than has sat for the last 18 years or so, thanks.
    Mar 2008
    I had the same problem on my machine in the spring and last September I worked with a guy in the UK with the same problem. Not to get your hopes up, but I got mine going and I think he did too. Here is some info on the resistor, the stock one is available, but not in small quantity, I was able to get this one from Newark, the only difference is the lead spacing, there is enough wire to make it work:
    81K6294 3 In Stock 5.10 Film Capacitor; Voltage Rating:1000VDC; Capacitor Dielectric Material:Polyester; Capacitance:0.1uF; Capacitance Tolerance:+/- 5%; Lead Pitch:22.5mm; Package/Case:N; Series:160; Termination:Radial Leaded RoHS Compliant: Yes 160104J1000N-F
    The info on the other component is: I don't know how much help this will be. The component was marked with P/D,
    this looked like a brand logo. Underneath it had Z44OG.
    I have the e-mail of the guy in the UK if that is needed for more info.
    Nov 2006
    Scotland
    Control Techniques who took over KTK drives many years ago no longer support them.You could replace it with a Mentor,but unless you have a Mentor drive spare or can find one cheaply,it is not going to be a very cost effective repair.
    There are people who repair KTK drives in the UK.My personal recommendation is Machine Support Services.
    This is because the guy who owns the company is a drives engineer,he has test rigs where he can check and prove the quality of repair.Additionally he supplied Bridgeport with a modified field control card for these drives which has proved to be infinitely more reliable than the original KTK board.
    I have repaired these boards myself,bought the components from Machine Support Svs.
    Ok,it was slightly more expensive to buy from him than the local supply house,but I got the correct spec part for the repair and advice and assistance.
    My personal choice for a retrofit drive for one of these would be a Eurotherm 590.Smaller ones are more common and cheaper on the used market than Mentors.
    Mar 2008
    KTK Drive
    Did you get this machine running? What did you end up doing? I have a similar machine and I am having trouble with the spindle drive not starting at rpm's above 1200. It acts like it doesn't have the power.
    Jan 2009
    The big blue part is a varistor. It has high resistance at low voltages, and low resistance at high voltages. Usually used as a surge protector, i.e. it dumps high voltage surges to ground, but doesn't allow normal voltages through.
    I just got my Interact 1 Mk.2 powered up, and got the "relay ext. DC voltage missing." What to do now?
    Kevin
    Moderator
    Nov 2004
    The Emergency stop button if pushed in when powering up will give that alarm. Otherwise it is a bad 24 VDC power supply. There are 2 in the machine.
    George
    Mar 2008
    DC voltage missing
    I had the same thing and replaced one of the power supplies. You can use an off the shelf item. If it is the emergency stop, make sure it is out and press the yellow button and then the green one once for each axis as it passes over the axis reference. If the parameters are out of the machine and had to be put in you will have to put some numbers in for the axis end of stroke and so on. I got help over the phone from Heidenhain, but there may be someone reading this more knowledgeable about the details than I am.
    Jan 2009
    As a matter of fact, the E-stop was pushed in when the machine was powered up. I'll try again later today. Where are these 24v supplies? What do they power? Thanks for the replies!
    Kevin
  • Page 1 of 3 123 LastLast
    1. Where can I find X-Axis Driver Board for Interact 412 VMC ('89)
      By Skin in forum Bridgeport and Hardinge Mills
      Last Post: 01-28-2008, 12:04 PM
    2. Bridgeport interact 4 - KTK drive
      By luismlgomes in forum Bridgeport and Hardinge Mills
      Last Post: 10-12-2007, 04:05 AM
    3. Interact 412, Spindle Drive
      By JoshG in forum Bridgeport and Hardinge Mills
      Last Post: 03-25-2007, 04:48 PM
    4. HELP..retrofit interact 4 spindle drive?
      By camarogod98 in forum Bridgeport and Hardinge Mills
      Last Post: 01-22-2007, 05:12 PM
    5. 412 Interact Drive Board Trouble
      By bribol in forum Bridgeport and Hardinge Mills
      Last Post: 01-21-2007, 06:36 PM
