Old 10-26-2008, 09:41 AM
bbrreid is on a distinguished road
Machine Guard Open
Bridgeport Interact 1 mark2 Heidenhain 151B control
When I try to run a program or start the spindle I get the message "MACHINE GUARD OPEN " . the problem is , there are no machine guards on the machine, is there a machine parameter for this or maybe a faulty contactor/ relay.
Thanks to anyone who can help
Brian
BR
Old 10-28-2008, 01:16 AM
nimo100 is on a distinguished road
Dear Sir;
This problem is happen to me before, and the problem was switch of the gured is damage, tray replace the switch first.
Old 10-29-2008, 01:32 AM
Originally Posted by nimo100 View Post
Dear Sir;
Thanks for the reply the problem is I dont have any guards on the machine
BR
Old 10-29-2008, 07:42 AM
Moderator
machintek is on a distinguished road
It is a parameter. This control was used on machines with and without interlocked doors.
I have to get to my office and look at my notes. Do not know when time will allow that.
Do you not have the original parameter list?
George
Old 10-29-2008, 03:45 PM
George
Thank you for your reply.
I have the Heidenhain manual from the web site but I cant find
the original parameters I really would appreciate your help with this
Best Regards
Brian
BR
Old 10-30-2008, 06:49 AM
RMARCH's Avatar
RMARCH is on a distinguished road
Try These..........Good Luck !!!
Old 10-30-2008, 08:21 AM
Moderator
I believe the attached list is from a 2500 control.
George
Old 10-30-2008, 05:13 PM
gridley51 is on a distinguished road
I don`t think it is a machine parameter.I would think this message comes from the plc and the reason for it is the plc is missing an input.If Brian has not been messing with the PLC programme or changed parameter 77,I would hazard a guess that the machine has had a guard at one time which has been shorted out but which has now failed.
I have parameter lists and plc programmes for a 155B which uses the same parameters but this machine had handwheels and a guard so not a lot of use.
Mark.
Old 11-01-2008, 05:43 AM
Machine guard open
First of all a BIG thankyou to everyone who replied
I found the original parameter list and can now reveal the fix.
I had been playing around with the parameters trying to fix a problem (which I still have ) with the uploading of programs from PC to machine.but not with downloading using Heidenhains program. so parameter 158 had been changed from a "1" to a "0" I changed it back to a "1" and all is well.
I hope this helps if it ever happens to someone else.
BTW MP92 changes language. MP 77 changes RAM to EPROM "1"
Regards
Brian
BR
Old 11-01-2008, 05:52 AM
So Brian,it was an ID 10T error.
Mark.
  #11   Ban this user!
Old 11-01-2008, 05:59 AM
Mark what about the other problem I still have.
was that a Fife attempt at being witty
BR
  #12   Ban this user!
Old 11-01-2008, 07:06 AM
"Mark what about the other problem I still have."
What! Just the one. :-)
What is your other problem Brian?
The 'Open' sign on my new milling machine fatal-exception DIY-CNC Router Table Machines 7 02-14-2008 02:13 PM
open machine time Arty 3000 Employment Opportunity 4 12-30-2007 12:41 PM
Cheap machine guard? JamesJames Safety Zone 17 12-18-2007 03:45 PM
open machine time markjb Employment Opportunity 4 11-13-2007 10:51 AM
open source cnc machine plans Bill Davis Stepper Motors and Drives 0 07-28-2006 12:20 PM
