Old 10-21-2008, 07:40 PM
arobustus is on a distinguished road
Unhappy Help! Bridgeport axis kaput
Here is what happened: It got to the end of the stroke with the power feed & jumped the track in that it no longer moves left to right. I have heard of this happening before in fact seen it, but I forget what you do to set it to rights. I have this vague memory that there is a collar in there that encloses the worm gear that is designed to separate in extreme circumstances. Or has a shear pin or other such mechanism. This is an old change belt drive model. It is in a college machine shop. I am told this has happened before. I am thinking if I remove the handle mounting braces from the ends I can slide the slide over and expose the worm and see what is going on. One consideration is that it has DRO. I am wondering what the implications of that are. Where can I go for guidance?
Thank You,
-plh
Old 10-21-2008, 09:55 PM
NC Cams is on a distinguished road
DUH what model are you talking about????
Old 10-22-2008, 03:34 AM
mc-motorsports's Avatar
mc-motorsports is on a distinguished road
if your dead in the water, just take it apart and see what happened. Hit up the surpluss suppliers in your area and see if they already have a powerfeed unit removed and possibly disassembled, maybe you can just buy parts? Or check out icai-online.com if it's a factory installed power feed unit.
If it's an aftemarket chineese unit, good luck, probably better off just replacing it.
Old 10-22-2008, 07:47 AM
Moderator
machintek is on a distinguished road
might br that you broke the screw holding the feed nut in the nut block. loof beneath the table left side.
George
Old 10-24-2008, 07:33 PM
Model BRJ 1 h.p. Servo is Servo power feed Type 100. DRO is acuRite III Cat#387.
Thanx,
-plh
Old 10-24-2008, 07:35 PM
George
As soon as I can stop being a doofus & remember to bring a flashlight down here, I'll do it!
-plh
Bridgeport Z axis? jjh122 Bridgeport and Hardinge Mills 25 10-31-2009 08:39 PM
Bridgeport (look alike) Z axis andrewbishop66 Bridgeport and Hardinge Mills 3 03-01-2007 04:23 PM
Sherline Speed Control kaput mikkojay General Electronics Discussion 2 05-04-2006 11:59 PM
Bridgeport Z Axis kewl_cat Bridgeport and Hardinge Mills 4 04-21-2006 08:39 AM
5 axis bridgeport JIMMY DIY-CNC Router Table Machines 2 12-15-2004 11:48 PM
