For some reason I thought you just remove the nut that mounts to the quill that either gets tied into a ballscrew or is used for a dead stop. I've removed that piece and thought the spindle would just drop out, doesn't work like that I guess. Can anyone point me in the right direction? Been searching for an hour with no luck. |
| You will need to remove the pinion, too. Take off the clockspring and remove the clutch housing. It's been a while since I have done it but the entire cartridge comes out pretty easily. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| What machine are you working on? Is this a J-head? I have a manual somewhere, but I think it must be on my PC at home. I found it on the net - Google around and you will find it. Heck - I recall posting it on this site a while ago. The pinion and clockspring are behind the downfeed handle on the right side of the head. I can not recall exactly how to remove the pinion, but I have done mine a few times without the use of a manual - it is somewhat intuitive once you get in there. I do believe you have to remove the downfeed clutch from the left side of the head to extract the pinion gear. Sorry I can't be of more help at the moment! Scott
| Not that sure but usually I drop the quill out after I have the entire top torn off off the head. Then I can remove the screws that hold the quill skirt and felt strainer. I do not believe the quill will come out unless those are removed. The quill pinion shaft supports the quill handle and pinion gear. The downfeed clutch comes off the left side. The clockspring off the right side (counterbalance spring for the quill). remove snapring on left side. Push pinion shaft to come out the right side. Why are you removing the quill? George
| Accurate Quill DRO for bridgeport mill? | amasters | Bridgeport and Hardinge Mills | 3 | 01-23-2008 12:08 PM |
| bridgeport 2j quill stepper question | Sparky_NY | Bridgeport and Hardinge Mills | 6 | 01-19-2008 10:29 PM |
| machintek: bridgeport quill splines | m37 | Bridgeport and Hardinge Mills | 10 | 07-17-2006 08:10 PM |
| What is the OD of a Bridgeport Quill? | widgitmaster | Bridgeport and Hardinge Mills | 6 | 01-07-2006 02:02 PM |
| Bridgeport quill running hot | CNCadmin | Bridgeport and Hardinge Mills | 1 | 02-28-2005 07:04 AM |
