Old 10-07-2008, 01:29 PM
RMT41 is on a distinguished road
Serieis 1 Interact 2 Heidenhain tnc 151
Hi I'm newbie here and bought a used 1986 interact mill powers up clear power interrupted put in manual press and hold power enable and cycle start all axis move to reference and I can move y axis and Z axis but the x axis will not move in manual joy stick or hand wheel it will move + small amount and not - off limit switch gives a x- limits . like I said new to this machine and looking for some help .
David
Old 10-07-2008, 08:32 PM
Moderator
machintek is on a distinguished road
You may have a bad parameter for the X travel limit.
Do you have the parameter list?
George
Old 10-08-2008, 06:50 AM
Yes I was reading the manual last night and found X limits setting paramter 44 45 will try this and see .
Old 10-08-2008, 09:15 PM
Moderator
Also check this. Press the MOD key, then use the arrows to scroll through the menu. One of those is user definable travel limits. That may be part of the problem.
George
Old 10-13-2008, 08:42 AM
Hi Machintek thanks for the help i got machine making chips one more question I set paramter 225 to 12 to have a tool comp libary but it is in mm can i change this to inch the dro is in inch but the tool libary says mm is there a paramter to set this in inch.
Bridgeport Interact 412/Heidenhain TNC 151 HELP? larrynsr Bridgeport and Hardinge Mills 16 03-17-2012 02:21 PM
Heidenhain tnc 2500 on Interact 308 GarageShop Bridgeport and Hardinge Mills 16 12-15-2010 04:57 PM
Heidenhain TNC 2500 in Interact 308 GarageShop Bridgeport and Hardinge Mills 12 08-24-2008 04:16 PM
Bridgeport Interact 1 Mk2 Heidenhain error joegille Bridgeport and Hardinge Mills 4 03-12-2008 07:07 PM
Interact 1 Mk2 with Heidenhain TNC155B rrbmachining Bridgeport and Hardinge Mills 6 03-22-2007 01:18 PM
