Old 10-04-2008, 10:48 PM
9 1/2's Avatar
9 1/2 is on a distinguished road
Zero C Axis
So I was doing some simple indexing on my 4th just now but couldn't find a way to zero it out.
I homes accurately but I mounted my work and needed to mill three flats 120 deg. apart.
I ended up jogging and switching to incremental mode, so job done.
Still, how do you zero the C?
F6 is "X"
F7 is "Y"
C?
Anyone?
Owen
B.C.I.T. Machinist CNC
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
FM-2 Help Z Axis Motor Amp Combo;FSSB Axis Not Set Shotout Mori Mills 2 11-29-2008 06:37 AM
How can I coupling a stepper motor axis directly to other axis? meknik2001 Stepper Motors and Drives 4 05-08-2008 01:54 PM
One axis (z-axis?) computer controlled testing device TsThorsell Stepper Motors and Drives 3 02-07-2008 12:38 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
