I have a BP S1 with BOSS 6.1 I haven't used it for about a year. When i turned it on it would not go into edit mode and i can't move any axis. I found that fuse 24 had blown. After replacing it I seems to blow as soon as power is turn on. Reading through the manual i'm having real problems tracing the diagrams. Inside the back panel everything seems factory standard. I would really appreciate some advice on solving this problem. thanks |
| The front panel has a UFP board behind it. It is a very sensitive board. It interfaces all the panel stuff to the ZDI. I would check the logic supply. You may have a bad cable, bad ZDI or a bad UFP. Is the ERR light lit? Or all the LED on the panel? George
| Thanks ever so much for the repley. I haven't had a change to look at the machine since last post. I'm not too clued up on electronics so it may take a while to go through what you've suggested. To answer your question the ERR light is not on the only LEDS lit are the ones that light after turn on. ie X axis but not Y or Z, when I select a different axis the LED doesn't change. It's as if the key pad and switches are unplugged. The checks I have done didn't find anything obvious but I will certainly do what you've suggested. Thanks again |
| New Machine Build- spline mode nurbs mode | cooltool | CamSoft Products | 4 | 03-10-2009 02:03 AM |
| MACH3 PLASMA IN EDIT MODE | john robin | Mach Plasma / Laser | 2 | 11-28-2007 11:05 AM |
| DX-32 freezing in edit mode?!?!? | mlbz420 | Bridgeport and Hardinge Mills | 6 | 05-15-2007 06:37 PM |
| Bridgeport BOSS6 SMD controll | Phooey | Bridgeport and Hardinge Mills | 4 | 06-16-2005 08:21 PM |
| Trying to drip feed a cnc boss6 bridgeport | cncboss6 | Bridgeport and Hardinge Mills | 2 | 03-11-2005 06:28 PM |
