Old 09-28-2008, 07:02 PM
jke6113 is on a distinguished road
Bridgeport 760 t16 encoder problem
I have a Bridgeport 760 t16 vmc, I found out that the x axis encoder is bad. I am looking for a place that does repair work, or is able to replace the encoder .
thank you
Old 09-28-2008, 07:36 PM
Moderator
machintek is on a distinguished road
I know of a VMC760.-16 I believe they had siemens motors. The encoder was a Heidenhain device. You should consult them about repair. Make sure the encoder cable is not the problem.
heidenhain is 1-847-490-1191
George
Bridgeport Torq Cut 22 - Spindle/encoder problems, bad? vettespeed Bridgeport and Hardinge Mills 11 07-28-2011 04:16 AM
Bridgeport R2E3 Boss 8 Encoder problems leftyrowe Bridgeport and Hardinge Mills 8 11-23-2009 08:03 AM
Bridgeport Series 1 R2E3 Encoder Count krz2_2000 General Electronics Discussion 6 05-20-2009 08:24 AM
Encoder problem? paulend Servo Motors and Drives 5 02-06-2007 09:01 AM
Encoder problem? pauls Industrial Hobbies (Support forum) 11 12-16-2006 06:51 PM
