Old 09-25-2008, 12:53 PM
batterzazu is on a distinguished road
COMPONET LOCATION HELP
Hi I was wondering if anyone could help me find what board and the location of the board is that has BR2 on it. I found it on the schematic but have no idea the location of it.
Machine is a Bridgeport Series I with the boss 4 control
Thanks Scott
Old 09-25-2008, 09:07 PM
Moderator
machintek is on a distinguished road
Would BR2 be a bridge rectifier?
I know where a few are mounted. On a heatsink behind the capacitors that are just beneath the tape reader.
to get to those, i remove the tape reader, Remove the screws that hold the capacitor chassis and slide that forward to reveal the heat sink. remove the heat sink screws and you will see the bridge rectifiers. I know that the X, Y, and Z axis bridge rectifiers are here. i do not remember if the 54V bridge is here too.
George
Old 09-25-2008, 09:36 PM
Thnk you George I did finally find the four you are talking about and they all check out ok. I now have to locate and test r4 (resistor?) and c2 (capacitor?) as well as output from T7 which I believe is behind the heat sink where the bridge rectifier's are. I have no electronic experiance and was scared as hell to dive into this thing but it is not as bad as I thought.
Thank you for your help
Scott
Old 09-25-2008, 09:46 PM
Moderator
Maybe in the white logic power cabinet?
George
Old 09-25-2008, 09:55 PM
I think I found it on the left side of the capacitor bank ane it has voltage coming in but nothing going out. I am going to remove it and double check it out at work tomorrow.
Thank you Scott
Getting the X and Y of my First CAM location vpcnc BobCad-Cam 4 06-22-2007 09:34 AM
What is the X & Y Location Joe Crumley Commercial CNC Wood Routers 3 04-09-2007 12:42 AM
Map your location Rekd CNCzone Club House 20 10-20-2005 09:49 PM
location mocnc DIY-CNC Router Table Machines 15 04-08-2005 04:12 PM
location? fastolds Surfcam 11 12-02-2004 01:58 AM
