Old 09-16-2008, 09:06 AM
Ingchema is on a distinguished road
Unhappy Problem with my EZTRAK 3-axis
Hi
I have one EZTRAK 3-axis with version 4.00/5.66 and up , series II REV. AA, I having problems with the machine, when star to run one program at any diferent part of the program the machine stop and turns off (the screen) is only running the spindle, also the machine stop too when a touch the keyboard, we clean the control panel and the keyboard, clean the filter, fans, even use another keyboard, but nothing happen, can you help me please?
Chema
Old 09-21-2008, 02:47 PM
NC Cams is on a distinguished road
shut machine off
First unplug the machine Kboard and plug in regular keyboard inside cabinet.
Reboot and exit to DOS once boo up finishes .
Run C:\DEFRAG.
Then run C:\SCANDISK
If SCANDISK finds/shows errors, you can have it fix them. If SCANDISK can not fix, you may need to replace HDD.
If by chance you have a new HDD that is not of BPT formatting, this could be your problem - BPT format is 504MB ONLY. Larger size format will NOT WORK!!!
When replacing HDD, you have to partition C: drive to 504MB ONLY. or else software will get scrambled as data is stored. You will have to reload software on new HDD from back up disks.
YOu do have B/U disks I hope.
Need Help!- Bridgeport EZtrak startup problem premierpatterns Bridgeport and Hardinge Mills 15 01-27-2010 04:37 AM
Problem with my EZTRAK 3-axis Ingchema Trade Shows and Events 0 09-16-2008 08:59 AM
EZTRAK DX II Problem JPMProto Bridgeport and Hardinge Mills 8 06-13-2006 10:12 PM
eztrak sx problem(s) DGeoLab Bridgeport and Hardinge Mills 2 05-20-2006 10:18 AM
EZTrak with factory installed 3rd axis. Gncc50 Bridgeport and Hardinge Mills 2 04-08-2006 02:13 PM
