Old 09-06-2008, 09:40 PM
v488 is on a distinguished road
Cool V2XT problem!!
When i turn on my V2XT " BMDC Board ", the screen gets to where it says BOSS DX32 and all the numbers start running across the bottom of the screen. It should do about 10 lines of numbers and the " BOSS DX32 " goes off the top of the screen than the Home screen should come up..... What it is doing now is running hundreds of lines of numbers accross the screen for 2-3 minutes than stops at a \ and its stops there dead. I have a boot disk and have resetup the Hard Drive many times but this does not help anymore. Is the Hard Drive Bad?.......Thanks Mike
Old 09-07-2008, 11:30 AM
Moderator
machintek is on a distinguished road
Maybe. But to read the hard drive correctly, the hard drive parameters in CMOS must be correct. It is also possible to contract a "virus." None of these are corrected by the factory back up disk.CMOS also affects the ability to read the floppy.
What is necessary to resurrect a hard drive from scratch is a DOS 6.20 boot disk (to FDISK and format), a full set of DOS disks, and a version of machine software meant for DOS 6.20, and some DOS and PC knowledge.
How old is the hard drive? Is it original? If indeed the hard drive has issues, I would consider a DOM (disk on a Module).
Try going to DOS and doing a scan disk and a defrag. This may tell you something about the hard drive as well.
George
Old 09-07-2008, 05:33 PM
I went into DOS and did a scandisk & defrag and both were 100% OK. Checked CMOS and everything looks OK, floppy drive runs . I've been using a DOS 6.22 Boot Disk with utilities & Explorer/Discovery/V2XT-DX 2.30_4.54 w/MS DOS 6.22 Disk from EMI that is susposed to be for Hard Drive Recovery. I do not have ANY factory back up disks for this mill. I got this mill used so i'm not sure if it is the original Hard Drive, mill was ran without an air filter and coolent got inside the cabinet so the Hard Drive is dirty. When i went to remove it i seen that the screws were only halfway put in so i'm sure its been fulled with before. What is needed for a DOM setup? After turning mill on and off about 20 times it did come up ok but now won't again. .........Thanks Mike
Old 09-07-2008, 09:48 PM
Moderator
The only acceptable hard drive mounting has the hard drive suspended by springs.
Sounds like you have the original bracket with the 4 rubber isolation mounts.
I am not familiar with EMI software.
The DOM will plug into the IDE port on the IO board or mother board and emulate a hard drive. EMI sells them.
George
Old 09-07-2008, 10:25 PM
9 1/2's Avatar
9 1/2 is on a distinguished road
Here's a link to the OEM files for my 99 V2XT. Its in a zip file You can try it if you think it'll work.
Owen
V2XT 1999
B.C.I.T. Machinist CNC
v2xt post jrrhotrod Post Processors for MC 25 12-10-2008 06:20 PM
V2XT with a New BUG up its A$$ !! Again... v488 Bridgeport and Hardinge Mills 2 05-26-2008 02:55 PM
Threadmilling on a V2XT rfdoyle Bridgeport and Hardinge Mills 4 05-16-2007 10:06 AM
V2XT IC identification help Riverside192 Bridgeport and Hardinge Mills 2 07-26-2005 06:36 PM
Surplus V2XT matchlite Bridgeport and Hardinge Mills 5 03-29-2005 07:07 PM
