Old 08-27-2008, 11:39 AM
smirob is on a distinguished road
Series 1 Retrofit
Hello again guys.
I'm wondering if anyone has replaced those old permanent magnet BOSS Steppers, for a Nema 32 Hybrid? The reason behind the question, is the 32's have 1/2" shafts, and the BOSS motors have 5/8". Because of this, I need to find some 1/2" Taper Lock's to mount the new motors onto the old belt pulley's.
It would be great if someone had done this already, and had part numbers, but if not, maybe you can point me in a direction to find the Taper Locks.
Thank you,
Rob, MI
Old 08-27-2008, 10:15 PM
n174k is on a distinguished road
A 1/2 id x 5/8 od split bushing appears to be a quick option.
n174k
BP series II Boss retrofit wyobmf Bridgeport and Hardinge Mills 19 12-17-2011 09:33 PM
Newbie- BPT Series 1 Retrofit Questions bnoji Bridgeport and Hardinge Mills 15 07-14-2008 02:34 AM
Bridgeport Series II un-retrofit. Buddy0228 Bridgeport and Hardinge Mills 2 05-01-2008 03:39 PM
Bridgeport Series II Retrofit Cold Fusion Vertical Mill, Lathe Project Log 143 06-30-2007 09:37 PM
Series 2 Interact 4 Retrofit UKRobotics Bridgeport and Hardinge Mills 1 05-14-2006 07:36 AM
