Hi, I Just turned on my machine and the control does not come on. It was working earlier in the day. None of the drives come on and the controller does not come on. The spindle motor fan comes on and the light that i have plugged into the side of the control works. The Machine is running from a rotary phase converter. Where should i start ? Thanks Ray |
| Thanks Guys !!! I have checked the Fuse in the control and turned all the trip breaker off and on again and still the same thing. I don't see any other Fuses anywhere. Tomorrow morning i will switch to the other Roto Phase Converter and see if that helps. None of the relays in the panel back light up and none of the Axis Drive Boards light up. The Drives just don't kick on. Ray |
| Typically the maintenance manual has wiring diagrams as well as a trouble shooting section that advises you where to look for what voltage. First a note that Bridgeport had a service report that negated a warranty on a machine running on a phase converter. Now check power in, all three phases. Next check the 24 VDC power supplies. The TNC2500 had a 24VDC supply that fed the control logic power supply. There was another one that ran the relays. If no power out, is there power going into these? If not follow it back. George
| Hi George, Thanks for the info, I will check the 24 VDC wednesday morning and get back to you. I already checked the 240V coming in and it was fine. Both the relays and control are not coming on, so is it likely they both went at the same time? Probably not. We will see. Thanks Again Ray |
| Those power supplies are protected by CB7 (circuit breaker 7) a 3 amp device. Power to that comes from T3 which is protected by CB3 a 10 amp device. Where does the power stop? George
#11
| George, I just took PSU1 out and looked at the board and from the back side behind a round back Diode or what ever it is, looks a little burnt. On the front side of the board that round black Thing has a V35 on it....Also has GI, RW005m and 8832 printed on it. Starting to wonder if it's the power supply board. Thanks Again For your Help !!! Ray |
#12
just to confirm, there is ac power right up to the power supply, correct? George will know much better than I , but I frequently find stuff that gets hot in some of these old machines..... 8832.....gee just made it's 20th birthday, mebbe the candles got too hot..... |
| Bridgeport Interact - Heidenhain TNC 2500 | nycooh | General CNC (Mill and Lathe) Control Software (NC) | 3 | 06-08-2011 04:01 PM |
| Bridgeport Interact 1 - Heidenhain 2500 | nycooh | CNC Machining Centers | 2 | 07-26-2009 05:40 PM |
| Bridgeport Serier II Interact 4 (Heidenhain TNC 2500) | elhosseiny | Bridgeport and Hardinge Mills | 15 | 11-21-2008 06:28 PM |
| Bridgeport Interact 1 - Heidenhain 2500 | nycooh | General Metal Working Machines | 0 | 06-25-2007 04:59 AM |
| Bridgeport Interact 1 - Heidenhain 2500 | nycooh | CNCzone Club House | 0 | 06-25-2007 04:56 AM |
