Old 08-25-2008, 05:17 PM
JNFSWE is on a distinguished road
Bridg. 760\22 Heid TNC 370
Hello again,
I am having a problem starting a new line without using the soft keys. Maybe I should put it this way, I want to start a new line and put whatever word addresses in it I choose if I use the soft keys I can only have one x or y or z and I am limited to what characters I use. Hare is an example of what I would like to input in line 8:
7 ....
8 L x-123 y123 f123
9 .....
Tnnx,
J
Old 08-25-2008, 09:18 PM
gus gus is offline
gus is on a distinguished road
re
what on earth are you talking about?
hit the 'L' key it will walk you through a linear interpolation
hit the x key it will do a one axis move.
explain more clearly your problem
INT412X HEID.2500 Jurek Bridgeport and Hardinge Mills 3 05-18-2008 05:50 PM
