Old 07-21-2008, 06:31 PM
pjeran is on a distinguished road
Problem with a KTK drive
I am having an issue with the KTK drive on my Bridgeport Interact 1 Mk 2. From a cold start, the program will start up the spindle and run the job just fine, but when the spindle stops for a tool change, it will just spin down to a stop, not the quick stop that I am used to. The brake does not engauge and the program hangs.
If I look at the KTK board, LEDs 5,8 and 9 are lit up along with the ins trip LED. The display reads 00 and LEDs 2 & 3 are off. If I hit the reset button, the ins trip LED goes off and LED 3 turns on and I can reload the program and restart the spindle.
Any thoughts on what is going wrong and what I can do to fix it.
Thanks in advance.
Paul
Old 07-22-2008, 01:26 PM
Moderator
machintek is on a distinguished road
Need your email address. My service notes are 4 MB and the manual I have is 20MB.
George
Old 07-22-2008, 01:29 PM
George,
Thanks for the help.
pjeran at cableone dot net will work
if that does not work I can PM you another address that can handle the 20MB file.
SL-30 Vector Drive problem Bigbear8291 Haas Lathes 4 03-17-2008 01:03 PM
Spindle Drive problem - need help ;) Dancy Fanuc 3 02-01-2008 06:26 PM
Gecko drive problem contractdesign Bridgeport and Hardinge Mills 8 07-25-2007 09:54 AM
problem with Yaskawa V7 drive rebrumm Phase Converters and VFD 4 05-22-2006 05:40 PM
Siemens drive problem bigtomt Machine Problems, Solutions , Wireless DNC, serial port 2 02-27-2006 08:38 PM
