Old 07-18-2008, 01:06 PM
kenshi is on a distinguished road
looking for circuit diagram
hello,
I have a Bridgeport J-Head vertical mill, but I can't use the cross and long feed system because the drive of the DC motors is burnt out. the problem is in the SCR abd Diode wiring.
I'm looking for the circuit diagram for the motor DC drive. if any one can help me I will be grateful.
Thanks,
Sami
Old 07-18-2008, 06:17 PM
gus gus is offline
gus is on a distinguished road
re
Let me guess, it is a 1951 with gearbox x axis power feed and a yang shen brand y power feed circa 1997..........................
Old 07-18-2008, 07:54 PM
NO, it's a 1968 I think with long & cross feed powerd by 1/2 HP DC motors, one feed control circuit and two change over relay for the DC motors.
my problem is with the feed control circuit ...
Old 07-18-2008, 08:34 PM
Al_The_Man's Avatar
I just converted one to a Baldor BC-140, I used the existing SCR's and heatsinks.
I could not find a complete schematic, this is for the 90v 12amp 1 HP motor.
If yours is only 1/2 hp, there should be no need to use the bigger SCR's.
Old 07-18-2008, 09:15 PM
lakeside53 is on a distinguished road
I have the board level and wiring schematics for the 6f/8f BP drives... Send me your email address.
Old 07-18-2008, 10:39 PM
hi,
about the feed motor, I have a 110v DC motor, my problem is not Witch SCR to use. it's how to wire the two SCR with the three Diode's in the circuit board controller.
Old 07-18-2008, 11:23 PM
Al_The_Man's Avatar
I am not sure what you want exactly.
If you want the SCR bridge diagram, I can describe how it is wired and how the connections can be identified.
Is there is a 6 pin plug connecting the SCR/Diode bridge to the Pct?
Old 07-19-2008, 10:44 AM
Kenshi - check your email. The 6F schematics have been sent.
Old 07-19-2008, 05:42 PM
Thanks "Lakeside" for the schematics. I am not sure if this is the correct diagram of my controller, But I will check it.
the controler came with 12 pin plug. that conected to change over relay circuit.
I have analyze my circuit controler board and came with this scheme. I post it.
but I think there is something Wrong with this circuit. I don't know how to conect the SCR with the Diode's.
maybe someone can help.
note:
sorry for my bad english.
Name:	SCR Bridge.jpg‎
Old 07-19-2008, 08:08 PM
Al_The_Man's Avatar
To me it appears that you have the three diodes reversed.
The version I have, all three diodes on the heatsink have the cathode's to the heat sink, not the anode's as you show it.
Two complete the bridge, and the third is the back emf diode, which in your case is shown normally forward biased.
One heatsink is DC+ the other DC- and are hot, so they should not be connected to ground accidentally.
I can draw up the bridge as it should be and post it for you, by tomorrow.
Old 07-20-2008, 10:14 AM
Al_The_Man's Avatar
Here is the connections I have for the bridge, hope this helps.
The DC+- from the heats sink are the motor connections.
  #12   Ban this user!
Old 07-20-2008, 10:32 AM
the problem that I can't reverse the Diode's or the SCR's, because the heatsinks is made of one piece of aluminium each one.
if I send you a photo of the controller board, maybe this will help.
also if you can draw up to me the bridge I will be grateful.
Schematics/Circuit Diagram for 3 Axis Driver with Parallel Port Interphase joprinz General Electronics Discussion 13 07-13-2008 03:13 PM
help with wiring diagram for C6 CNC JDsto Syil Products 6 01-09-2008 06:37 PM
Master PCB diagram 10T guhl Fanuc 0 12-07-2007 07:31 AM
Wiring Diagram SCHMEOW General CNC (Mill and Lathe) Control Software (NC) 1 10-20-2007 11:40 PM
Anyone have an X2 circuit board diagram? dang Benchtop Machines 2 10-07-2007 02:03 AM
