Old 07-15-2008, 03:31 PM
PierrePrototype is on a distinguished road
TNC145 SERIES1 BRIDGEPORT
Hi Everyone
I am new to CNC zone but not CNC. Looking at a Bridgeport Series 1 interact Mill for my shop. It has a Heidenhain TNC 145. Since my experience is largely with Roland CNC's and DeskCNC running on a retrofit Adcock Shipley 1ES I have some questions about the operation of this control. Firstly How much memory does the TNC 145 have for G Code? This may sound silly but I have read through the PDF's available on the Heidenhain web page and have not found what I am looking for.
Obviously it is directly proportional to the size of the program I can run since I also read that "drip mode" was not an option on this control. Second was it ever an option to upgrade the memory?
I have done quite alot of research into this machine and it looks quite well suited to my aplication. This is the only issue I have come across that I need to clear up.
If anyone has this information or has a machine running the same control and wouldn't mind sharing their knowledge on this I would greatly appreciate it.
PS SORRY IF THIS IS ON THE WRONG FORUM/ AREA I AM A NEW GUY HERE!
Pierre
Old 07-15-2008, 04:00 PM
gus gus is offline
gus is on a distinguished road
re
While the 145 is a solid control, it does not take g code in any way, only heidenhain conversational. There is no way to increase its memory, and I am unsure if you can transfer blockwise on this control.
I have many miles on a 145, but it has its limitations. It is also 2 1/2 axis control, so no 3 axis contouring.
Old 07-15-2008, 04:39 PM
thanks
Hi Gus
Thank you for the rapid reply there.
Someone who knows whats going on with that control in particular.
Exactly what I was looking for.
Thanks a stack for the good info.
Best Regards
Pierre
Old 07-15-2008, 05:05 PM
gridley51 is on a distinguished road
I can put you in touch with someone in S Africa who has just installed the same machine with the same control.He is also new to it.
Mark.
Old 07-16-2008, 02:59 AM
Hi Mark
That would be great if you could put me in contact with the person you mentioned. My email add is hduraan@mweb.co.za.
Best Regards
Pierre
Old 10-26-2008, 08:50 AM
jaztau is on a distinguished road
Hi Pierre im also in South Africa and also have 2 off these machines, maybe we can put our heads together on this one.
Regards
Jan
Help w/Bridgeport series1 textron CNC MrHorsepower Bridgeport and Hardinge Mills 28 02-10-2010 01:49 AM
bridgeport 2/heidenhain tnc145 Dar Bridgeport and Hardinge Mills 4 03-19-2007 08:05 PM
bridgeport 2/heidenhain tnc145 Dar Bridgeport and Hardinge Mills 1 03-12-2007 03:24 PM
What VDU for Bridgeport Interact Series1 ? awemawson Bridgeport and Hardinge Mills 5 03-10-2007 01:18 PM
bridgeport mill series1 boss 4? jerid1 Bridgeport and Hardinge Mills 5 07-07-2005 06:10 PM
