Old 07-08-2008, 02:56 PM
hmc710 is on a distinguished road
Servo or ball screw
I have a bridgeport series II interact II mill with TNC145 control. The x axis is starting to shutter as it moves. I did not notice this before. We have been running one job on the mill with a vary small operation area of probably 4" x 6". This is not a productin job, very intermittent. It feels like the x axis is dragging and it stutters when it moves. I pulled the way covers and the ways were a lot dryer than the ball screw with was well oiled. I cleaned and oiled the ways. The pnuematic oiler appears to be working. The y axis is very smooth. I manually moved the x axis full travel to make sure the oil on the ways was distributed. I programmed a rapid rectangular move to see if the shudder was there at "high" speed and it is but not as noticable when doing the normal program which runs at 15 IPM. Could it be a servo condition, or is there just not enough oil in the ways?
Thanks,
Old 07-08-2008, 03:03 PM
Al_The_Man's Avatar
After a while the metering points at the end of each lube line start to clog, they should be replaced every 5yrs or so, the pump should also be removed and cleaned as the oil starts to coagulate, and the lines blown out.
Old 07-15-2008, 12:21 PM
JoBwan's Avatar
JoBwan is on a distinguished road
Thanks,
hmc710,
It could very well be a servo problem, Can you swap the "x" and "y" motor to see if the studdering moves with the motor or stays on the same axis? If it moves , it is probably a dirty encoder or tachometer. Just a thought.
Just a good ol' boy, never meanin' no harm.
Joe
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
Wanted: V2XT servo/ball screw pullies v488 Bridgeport and Hardinge Mills 2 10-22-2005 09:38 PM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
z axis servo on main ball screw or down feed handle replicapro Benchtop Machines 5 10-29-2004 10:25 PM
