Can anyone recommend a source for BT tooling with the 1/2"x13 threading? Any thing I find on Ebay is 12mm ........... ![]() I have a full collet set in 1/2" and don't want to get rid of it all. Owen
__________________ 9 1/2 B.C.I.T. Machinist CNC |
| BT is a Japanese spec they are ALL metric. CAT, on the other hand, is American and WILL have imperial threads. If you have a BT with 1/2-13 threads it is either bastardized or custom made. To sum it up, there is a good chance your tool is a CAT 30.
Hmm okay well that's excellent info. My system is definetly not a custom set up. It is a Kurt Power Draw bar. Though I though Machintek said the Kurt system was 1/2x13.......... I must have a wire crossed. Thanks for the tip on the CAT30, I'll hunt around and see what that turns up. Peace ![]() EDIT: Found this site showing the specifacations on the CAT tooling. Note the TPI stated for the 30 is in fact 1/2x13 CAT specs
| Some of it is listed as NMTB 30, NT 30 or ISO 30. Everything I have is 1/2"-13. I just recently drilled out my spindle (it was an Erickson quick change) to use a power drawbar, and was wondering about the Kurt system. Does yours use a special drawbar? I'm under the impression that they are specific to the power draw bar system. It looks like some systems use a splined head instead of a hex. Where is your drawbar control located?
__________________ "ain't much that can't be repaired, rebuilt or replaced..." |
| BT30 Spindle project | H.O | Vertical Mill, Lathe Project Log | 152 | 02-25-2012 10:31 PM |
| BT30 tool holder DXF | Master_CNC | Mechanical Calculations/Engineering Design | 5 | 11-14-2007 08:03 AM |
| BT30 and R8 tools | cncuser1 | CNC Tooling | 1 | 10-01-2007 03:42 PM |
| BT30 or BT40 ? | kimhan | General Metalwork Discussion | 9 | 06-21-2007 08:57 PM |
| BT30 taper spindle to cut tool steel? | grantmi1 | General Metalwork Discussion | 0 | 05-31-2005 11:02 AM |
