Old 06-30-2008, 10:21 AM
evo123 is on a distinguished road
ezpath fault
hi guys,
got a problem on bridgeport lathe with ezpath s system.
interrmitant fault.
gp fault-fatal error
m/c integrity is not compromised
software will try to restart to clear the error
system error-possible pointer error.
any ideas
dave
Old 06-30-2008, 03:42 PM
Moderator
machintek is on a distinguished road
This is a mother board fault. Check your +5 VDC logic supply. You may find this low. Clean the mother board edge connection and reseat it into the backplane.
Also look if the logic power supply cable plugs into the backplane or if it uses the screws and terminals. There was a recall/upgrade to a harness that eliminated the plugs. Too much resistance. If you need to adjust the power supply. It has to come off the Control In a Box front cover as the adjusting Potentiometer is hidden. Be careful. Electricity can bite.
Also EMI told me that these power supplies were not self regulating even though they had the potential. He was working on a add on voltage regualtion kit.
George
Bridgeport/Romi EZPATH Schematics NC Cams Bridgeport and Hardinge Mills 5 06-24-2011 06:00 PM
Ezpath Data Inquieytigation NC Cams Bridgeport and Hardinge Mills 2 01-18-2009 12:12 AM
Ezpath Iiis Error Msg Zombiestomp General Metal Working Machines 1 10-27-2007 09:08 AM
EZPath DX32 control help needed, please!! VSMIGuy Bridgeport and Hardinge Mills 1 01-28-2007 10:49 AM
Bridgeport EZPath help needed! VSMIGuy General Metal Working Machines 1 01-08-2007 05:58 PM
