Old 06-30-2008, 09:10 AM
leeputman is on a distinguished road
Red face BPT R2G4 Fanuc 11MA Crash
Thanks for looking at my mishap. I was goind a simple G83 Drill Cycle when I crashed do to changing Tool Numbers for unity and forgeting to update the tool length register. Ops!
So I ramed a small drill into my fixture plate and heard the spindle labor some.
A simple fix, new drill and ( Now I have no % rapid override") Nothing else was changed and I even shut down and restarted. Still no, rapid override. Makes it a little difficult to step through a program.
Can anyone see an obvious thing that I have overlooked?
Thanks,
Lee
Old 07-21-2008, 07:31 AM
I found the problem.
The 4 position % over ride switch ended up being a 5 position switch. I am not sure if I did this when I reacted to the crash or not.
I found the area of the ladder diagram that shows the logic of the switch. At first cycling through the switch positions did not cause the logic to change. Then after I had the panel apart and mess around I could see the hi low signals changing. This is when I found the extra position. Ended up that I had 100% at both extreams of the switch.
It's working now.
Bridgeport R2G4 with Fanuc 11MA leeputman Bridgeport and Hardinge Mills 23 09-15-2009 06:28 AM
I need a crash course!!! dpotts Diemaking and Diecutting 4 09-03-2009 07:09 AM
Need Help!- sl-30 crash bowhunter Haas Lathes 5 10-14-2008 12:53 PM
Drip Feed into a Fanuc 11MA Controller on Bridgeport R2G4 V Mill leeputman Mastercam 9 04-28-2008 12:10 PM
Bridgeport R2G4 Dripfeed from mastercam leeputman Bridgeport and Hardinge Mills 5 05-05-2007 09:41 PM
