Old 06-18-2008, 04:43 PM
ivangene is on a distinguished road
EZ Trak Parameters set-up, check and adjust
I am going to ask what I think are obvious questions, but want to make sure I get it right
Parameters, 11235 enter enter
Machine Series (1) --- what are my options, how do I know for sure
x max travel (30.0) --- this seems about right
y max travel (12.0) --- also seems fair
x offset (24729395.0) what the heck?
y offset (26055426.0) yea, same thing??
X backlash (0.002) this is a number I just put in but would like to know how to check, adjust and verify.
y Backlach (0.001) same question as the X
x lead error (0.0004) this is also something I would like to KNOW how to check, set and verify
y lead error (-0.0004) same question as X
I had to re-load the system and since then I have been wondering if I have these right... the machine runs fine, but as with anything it could be a lot better if I did this correctly. I have had some issues with the "bugs" in version 6 but cant seem to get a copy of 8 anywhere. So for now I will work on tighening up the unit and dialing it in as best as I can
Thanks for your time in helping me
Ed
Old 06-19-2008, 07:19 AM
Moderator
machintek is on a distinguished road
Dove tail ways = S1
Box ways = S2
S1 X travel = 30.0 inches, Y = 12.0 inches
X and Y offset is distance from home to part program zero. This will change each time you set zero.
Backlash is mechanical lost motion compensation. Always a positive value.
Lead error compensation also known as pitch error compensation, is a correction factor for how the ball screw was ground. This can be a positive or negative value. Usually done at Bridgeport with a laser but can be done with a step gauge
I have never seen a value greater than .0035 inches for backlash and lead error in a decently healthy machine.
George
How do I adjust the backlash S Lovette Shopmaster/Shoptask 3 03-15-2010 01:57 PM
How do I adjust the Gibbs? CNCadmin General Metal Working Machines 20 05-13-2008 06:06 PM
how to adjust Backlash. cnccustom Syil Products 4 11-21-2007 12:28 AM
need help to adjust servo system webcruiser8 Employment Opportunity 2 11-27-2006 02:36 PM
Rong Fu 31 spindle adjust grinderdust Benchtop Machines 11 11-23-2006 01:13 PM
