Old 05-26-2008, 03:35 PM
NC Cams is on a distinguished road
Ezpath Data Inquieytigation
I am looking for information about the Expath 2, 2S add 2SD. Basically, I'd like to know what each can do that the other cant do.
Which have CSS?
Which can send out a voltage signal to index a tool changer?
You see, I have a electro/pneumatic 4 position turret that fit on an old Fanuc 5T and it needs a 24vdc signal to trigger the indexing of the tool. From what I know the 2 won't and the 2SD will. What about the 2S???
I'd like to adapt the tool indexer to the 2( ) but need to konw which can/will trigger a tool turret.
Does anyone have a wiring schematic for the 2S in PDF? I have the 1, 2 and 2SD but no 2S.
Also, does anyone have a schematic for the CONEXP board used on the 2SD and perhaps the 2S?? Again, either PDF or perhaps a good photocopy would do.. PM me if you need to....
Old 05-26-2008, 07:33 PM
Moderator
machintek is on a distinguished road
Original EZPATH1 did not have CSS. The rest had it.
EZPATH S has a pneumatic chuck option, bar feeder option, auto tailstock option but I did not see a turret option. I have installed a electric turret on a EZPATH 2SD at Mercedes, so I know that is do-able. I have a EZPATH 3 in my area which came with a hydraulic chuck and a electric turret.
I do not believe the older EZPATH 2 supported a turret.
EZPATH SD also supported a electric turret.
George
Old 01-18-2009, 12:12 AM
Geopge - check for PM
Bridgeport/Romi EZPATH Schematics NC Cams Bridgeport and Hardinge Mills 5 06-24-2011 06:00 PM
Ezpath Iiis Error Msg Zombiestomp General Metal Working Machines 1 10-27-2007 09:08 AM
Data-Cut plans pervita DIY-CNC Router Table Machines 1 08-21-2007 10:23 AM
EZPath DX32 control help needed, please!! VSMIGuy Bridgeport and Hardinge Mills 1 01-28-2007 10:49 AM
Bridgeport EZPath help needed! VSMIGuy General Metal Working Machines 1 01-08-2007 05:58 PM
